Fog Lights on Base Pre 2016 Model
dmlns1092
VA
2013 Ford Explorer
Thanks for sharing, nice job. I bought the same ones today. Any advice on how to secure the light into the light well?
Bucho
09 LR2
Just an observation. You bought driving lights, not fog lights. They have a narrow beam that points straight down the road (same as headlights), unlike fog lights with a wide beam lighting the road right in front of the car and sides to some extent.
Razziel24
Guayaquil
Explorer 2012 3.5 V6 Base
Hi, did you finish wiring them ?
Im stuck
I got OEM replacement fogs and the OEM switch with the fog button, but I need the wiring diagram, please help asap.
Thanks.
Andy.
Razziel24
Guayaquil
Im stuck, got everything, the oem fogs, the oem switch, made the holes on the bumper... but I need the wiring diagram.... help
Razziel24
Guayaquil
Got them installed, but I still need the wiring diagram, anyone has it by any chance ?
Razziel24
Guayaquil
Please help, there sholuld be a wire going to the fuse box and then to the OEM switch, I cant find this cable, im still stuck
royski
Virginia
2020 XLT
Anyone else have further information on this?
Fog lights were the only option tat I liked about the XLT, but could not justify the added cost of the other items that I did not want/need.
Razziel24
Guayaquil
I havent been able to find the wiring diagram, theyre still not powered, just installed. :(
RandyH2
MI
'11 Limited AWD
The original poster said he wired his to the amber parking lamps, so no wiring diagram really needed. Though perhaps your bulbs are drawing more power and that won't work?
nandan350
Houston, Texas
2012 Ford Explorer
The plastic cut out looks really good,nice work. i did the same thing in my Base model 2012 Explorer too taking it to the Best Buy Geeks, the guy made the cut nasty and it looks terrible now. I bought stock looking fog lamps(a pair) from ebay for $59 which included a switch and the entire wiring with fuse etc. Best Buy Geeks charged me $220 for installation including screws and stuff. I also had to buy stock Brackets from Ford dealer for mounting the lamps. I actually wanted to buy XLT headlight switch too but i already spent $300 so didn't want to spend more. the wiring and switch placement everything looks professional except for the idiot's plastic cut which now looks cheap. Also i am not happy with the light output which barely gives out any light, i think i need to change the bulbs now to a higher wattage, and also its focusing right in front of the car and making it useless. How did you do the fog lamp wiring in your car and what switch did you use? Also any ideas to adjust the focus the fog lamp in 2012 Explorer?
nandan350
Houston, Texas
2012 Ford Explorer
Razziel24 - Have you got the wiring diagram yet? i recently installed the fog lights to my Base Explorer. I bought it from ebay, it came with the lamps, switch and wiring, for $59. It exactly looks like factory. I also bought a pair of stock brackets($54) from a ford dealer, and got it installed by Best Buy Geeks, the wiring and installation was very professional, though i am not satisfied with the switch that came along(I wanted the XLT stock switch,but didn't want to spend extra money). but the cut in the bumper got nasty as the best buy person didn't cut it well and it looks terrible now. Also i can barely see the light from the fog lamp as it is too dim and is focused right in front of the car which makes the whole unit uselss. Is there any way to adjust the fog light focus? Thanks.
Miaheat
Scottsdale, AZ
2013 Ford Explorer Base
2013 Explorer Base Fog Lights Install
Does anyone know or have a video or images on how to install fog lights on 2013 Explorer base?
the dealer wanted to charge me $399 for the lights not including labor.. Crazy! So i am sure i can fine the fog lights for a better price. but i need some help with the install and also how to pop out the cover where i am going to put the switch which located in the left side of the driver where they have empty buttons for accessories..
Any ideas? or a step by step would a lot of help
nandan350
Houston, Texas
2012 Ford Explorer
Yes, that kit in ebay works 100% well. I have a 2012 base explorer. i bought the same kit, but from a different seller i believe, and got it installed by the Best Buy geeks. Works good, its been more than a year now, no complaints yet, be very careful when you cut the hole on the bumper, measure the exact outline of the fog lamp and cut accordingly, otherwise it will look ugly, that happened to me, the best buy guy messed up one side hole. That lamp is the exactly replica of the original ford fog lamp. so nothing to worry.
nandan350
Houston, Texas
2012 Ford Explorer
oh and one more thing, don't forget to buy the lamp holding clamps, both left side and right side, you can get it from any ford dealership, go to ford website and search the lamp diagram, there you can get the part number. the e bay kit doesn't come with the fitting clamps.
Cole3313
2013 Explorer
FogLights
I am trying to do the same thing and finding the headlight switch is my biggest problem. Did you get the fog lights in? Any words or advice on installing them.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Cole3313.:wavey:
As indicated in my PM, I have merged the thread you posted in with this existing one. The member who posted in posts 63 & 64 above seems to have found the OEM switch. Good luck with your project.:thumbsup:
Razziel24
Guayaquil
hey guys did you get your fogs working ? I havent had the time to keep looking, so i have everything installed as I stated before, even the XLT oem switch with the fogs button, but no wiring
jtc24
Kentucky
2013 Explorer Base
The plastic panel that conceals the area where the driving lights are installed runs all the way up into the front wheel well. Am I correct in assuming that this entire piece will have to be removed to get the lights installed?
Also, does the stock Base bumper cover have the necessary holes to insert the screws when installing the mounting brackets for the lights?
D Adding fog lights to 2016+ Base Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 43
T LED Fog Lights Modified 2011- 2019 Explorers - Tuning & Mods 25
M Fog lights 3000K Hid or yellow tint? Modified 2011- 2019 Explorers - Tuning & Mods 8
E H9 bulbs for fog lights? Modified 2011- 2019 Explorers - Tuning & Mods 0
T Fog Lights Rewire, need wiring diagram Modified 2011- 2019 Explorers - Tuning & Mods 2
B Fog Lights Modified 2011- 2019 Explorers - Tuning & Mods 3
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 24
N Fog Light or High Beam Memory Modified 2011- 2019 Explorers - Tuning & Mods 9
D LED fog lamp upgrade? Modified 2011- 2019 Explorers - Tuning & Mods 30
mmartin028 Leak in my fog light housing. Modified 2011- 2019 Explorers - Tuning & Mods 2
S 2014 XSport Fog light took a rock.. Modified 2011- 2019 Explorers - Tuning & Mods 3
J HID/LED Headlamps and/or Fog Lamps - GO LIONS!! Modified 2011- 2019 Explorers - Tuning & Mods 3
7 Fogged fog light Modified 2011- 2019 Explorers - Tuning & Mods 3
M Fog light replacement recommendations Modified 2011- 2019 Explorers - Tuning & Mods 2
3 fog light projector retrofit Modified 2011- 2019 Explorers - Tuning & Mods 6
W Custom Headlights and Fog by RIHIDS Modified 2011- 2019 Explorers - Tuning & Mods 25
B Hoen H11 Fog Light Xenonmatch Modified 2011- 2019 Explorers - Tuning & Mods 1
M 2014 fog bulb out warning Modified 2011- 2019 Explorers - Tuning & Mods 1
R Another Fog Lamb bulb question Modified 2011- 2019 Explorers - Tuning & Mods 1
A HID Fog Install Questions Modified 2011- 2019 Explorers - Tuning & Mods 20
K Halo Headlight/Fog idea Modified 2011- 2019 Explorers - Tuning & Mods 44
J Fog light conversion Modified 2011- 2019 Explorers - Tuning & Mods 1
M Hood Pod Lights? Modified 2011- 2019 Explorers - Tuning & Mods 3
W JHO Rear Tailgate LED Lights Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Courtesy LED loading-dock Hatch lights Modified 2011- 2019 Explorers - Tuning & Mods 6
S Sylvania LED REAR TURN SIGNAL/Flasher and Back up Lights. Modified 2011- 2019 Explorers - Tuning & Mods 5
Rainlord How to access/open sidemarker lights Modified 2011- 2019 Explorers - Tuning & Mods 1
B 2016/2017 Smoke Tail lights? Modified 2011- 2019 Explorers - Tuning & Mods 11
A new led lights front bumper and headlights Modified 2011- 2019 Explorers - Tuning & Mods 3
M Off-road lights to front bumper Modified 2011- 2019 Explorers - Tuning & Mods 0
A changeing license plate lights to LED Modified 2011- 2019 Explorers - Tuning & Mods 3
F Aux Driving Lights - switch options Modified 2011- 2019 Explorers - Tuning & Mods 5
expoman55 Roof Lights Modified 2011- 2019 Explorers - Tuning & Mods 1
E Dome light wire - LED Grill lights Modified 2011- 2019 Explorers - Tuning & Mods 6
R LED back up, license plate & puddle lights Modified 2011- 2019 Explorers - Tuning & Mods 28
F New LED lights.... Modified 2011- 2019 Explorers - Tuning & Mods 5
T Foot-well/Under-dash Lights Modified 2011- 2019 Explorers - Tuning & Mods 6
M Automatic Lights on a Base Explorer Modified 2011- 2019 Explorers - Tuning & Mods 13
L Ghost Shadow Under Door LED Lights Modified 2011- 2019 Explorers - Tuning & Mods 11
R New member - No auto lights with TRS harness? Modified 2011- 2019 Explorers - Tuning & Mods 10
J Traffic control lighting/police lights options/opinions? Modified 2011- 2019 Explorers - Tuning & Mods 5
K Lights mods! Modified 2011- 2019 Explorers - Tuning & Mods 6
SurrealOne New head lights WOW Modified 2011- 2019 Explorers - Tuning & Mods 38
T wiring diagram for 2014 Explorer XLT brake and rear turn lights Modified 2011- 2019 Explorers - Tuning & Mods 1
C Make lights flash Modified 2011- 2019 Explorers - Tuning & Mods 3
1 Replacing 2nd and 3rd row dome/map lights in an Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
G how to upgrade interior lights for 2014 explorer Modified 2011- 2019 Explorers - Tuning & Mods 1
A License plate lights improved Modified 2011- 2019 Explorers - Tuning & Mods 3
T Anybody added aux reverse lights like this? Modified 2011- 2019 Explorers - Tuning & Mods 13
W 2011 FORD EXPLORER LED Lights from carid? Modified 2011- 2019 Explorers - Tuning & Mods 4
Similar threads
