Fog Lights on Base Pre 2016 Model
tropicvi
St Croix, US Virgin Islands
2008 Range Rover HSE SC
If you use a hole saw, and then file it snug to the size of the lamp being installed (I used LED cluster lights as DRL's to augment the activated DRL), a windshield adhesive will securely hold the lamp unit in place with no brackets needed - the brackets are attached to the plastic anyway, so a press fit and adhesive is just as secure.
Join the Elite Explorers for $20. Gets rid of the ads!
twodogs603
Norfolk,Va
2014 ford explorer base
Adding driving lights
I know this has probably been discussed before but I did a search and couldnt find an answer.
I new here so bare with me. I just purchased a base 2014 Explorer. One of the things I want to do is add a set of driving/fog lights were the stock ones would go. Does Ford sell that as a kit, or do I have to buy all the parts individually? And is the truck already wired for it, with pigtails hanging behind the bumper? And I assume to get the factory look I would have to get a new headlight switch with the fog light button built in?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I merged your thread with this one on fog light installation. Hopefully it will be of some help.
twodogs603
Norfolk,Va
Someone has to know an answer to my questions.
On the 2014 base model, is it pre wired for the fog lights? Are there pig tails behind the front bumper to plug into the factory lights that I want to buy? And can I just replace the headlight switch with the one that has the fog light switch built into it?
What would be ideal, is to install the fog lights, plug them into pigtails hanging behind the bumper, and replace the headlight switch with the one with fog light option, and that switch just plug into the existing harness, and one Im hoping is back there for the foglights..
Is the truck prewired?
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
This is how the fog lamps operate. The Headlight switch should send a CAN BUS signal to the BCM (body control module) to activate the Fog Lamps. Based on the signal to activate the Fog Lamps, the BCM trips the built in fog lamp relay (BCM) and feeds power to the Fog Lamps. Based on this there is probably reprogramming of the BCM as well to tell it, hey yes I have fog lamps. Probably not something Ford will document.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Also if the wiring isn't hanging there then it's not installed. You can check the BCM to see if the wire is there. You can PM with your email and try to help you out. If you got the switch already and want to swap it out you might be able to see if the BCM even recognizes the fog lamp function by CAREFULLY inserting a wire in the empty slot on the correct plug where the fog lamp wire comes from the BCM and see if it powers up. If it doesn't then the BCM would have to have it's data altered to enable the fog lamp funciton.
twodogs603
Norfolk,Va
I do not have the switch yet. I was hoping the connections for the driving lights would be somewhere along the harness but I cant find any empty connections anywhere. In the schematics for the factory driving lights there is a pigtail that connects the light to the factory harness, but I cant find that connection. I find it strange that Ford would make a totally different harness just for the base model Explorer. I was hoping I could just replace the headlight switch and install the driving lights and plug them in. But guess that isnt going to happen.
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
Sounds like you have access to the OEM service manual. I see the plug you are talking about. Its not unusual to have different harnesses these days. If the plugs are not there the wire probably isn't at the BCM side. Since you have access to the manual have you checked the BCM plug to see if the wire is there?
twodogs603
Norfolk,Va
I dont have the manual. I just saw the parts info online somewhere...
jmr061
Wisconsin
16 Edge
Pr-16 Exp Sport
According to the manual its just a short pigtail basically running from the plug on the harness to each light. If they do equip it you would see a connector taped to the main harness in the vicinity of each fog light location.
twodogs603
Norfolk,Va
I dont see a plug anywhere so I think Im out of luck.
ABNparatrooper85
2014 Ford Explorer (Base)
Foglights
I recently purchased OEM foglight kit from Spyder (for 2014 Ford Explorer base), comes with all the necessary wiring, along with the switch. I also purchased an HID kit w/relay to replace the stock fog bulbs. My issue is that I never did a firewall pass through, and I have no idea of how to go about doing that. I purchased a fuse tap because I want to run it off the ignition fuse which is inside the interior fusebox that's under the steering wheel column. Hell, I can't even locate the fusebox, but I know the area of which it's located in, guess I gotta do some digging around. Is there any alternatives to doing a firewall pass through? The space is pretty tight, and it's a bit intimidating to me since I'm a beginner. Any suggestions?
Miaheat
Scottsdale, AZ
2013 Ford Explorer Base
2013 Ford Explorer Base Model Fog Lights Install/Wiring Instructions
I am looking to install fog lights in my 2013 ford explorer base model. As you can see from the pictures my Explorer just has what seem to look like a cap. I am currently looking to purchase a kit from Ebay link below.
The issue I am having is where exactly I need to drill holes or if I need to cut something out to make this work. This kit comes with the wiring and I am also looking for the install instructions on how to wire them and install them.
Any information would be helpful. If this kit is not a good fit, please let me know where I can find something more or less the same. I need to start from scratch since my car doesn't
http://www.ebay.com/itm/2011-2015-EXPLORER-CLEAR-DRIVING-LIGHTS-FOG-LAMPS-BULBS-BRACKETS-HARNESS-SWITCH-/221974905656?hash=item33aebc4338:g:MFYAAOSwFnFWDbpH&vxp=mtrhave fog lights and the dealer wants to charge me $800+ for fog lights and labor etc.
Thank you in advance
Extremerc12
2014 Ford Explorer Base
Purchased - Pre Owned 2014 Explorer Base
Hi everyone,
We are picking up the vehicle tomorrow. One other question that comes to mind is with regards to fog lights. I forgot to look, but are the covers in the front bumper cover removable, or do the light openings need to be cut open? Does the wiring exist, or are add on harnesses needed for the front left and right and back to the headlight switch assuming it has the correct headlight switch?
Thanks for the help.
Confair3
Phila PA
Ok, I got the oem switch, it came with the button for the fogs, and and additional position for the headlights (A) for the automatic headlights I guess.
Now the question is: there is a square socket on the back... will I need to buy another harness or can I somehow wire the thing to the fog lights to make them work ?
Actually, I was thinking about installing some generic fog lamps, and make them work with the original switch, is that possible ?
Another question.... what will happen if I turn the headlights knob to the (A) position ? Im guessing there should be a sensor somewhere to make the auto lights work, right ?
Could you post a picture of the oem switch with fog you have or possibly send me in a message. Thank you
Confair3
Phila PA
hello, i have a 14 base explorer. through a buddy i got the fog lights, brackets and everything on the diagram on ford parts / levittown ford parts . com. i still need a wire harness and just going to install my own switch inside the cabin( prob in the center console). my REAL QUESTION is the 4 screws that hold the housing to the backet and 1 nut and bolt hold bracket to the frame? seems like not enough. i have yet to take anything apart and start this project as im waiting for wiring.please LET ME KNOW if i need more screws/nuts/bolts - or if there is a picture/ video of install and you can post or point me in right direction. THANK YOU!!!
CommandPresence
Massachusetts
2018 Explorer XLT 3.5L NA
4 for each side seems right to hold the light to the bracket. There are additional screws that hold the bracket underneath the valance.
peterk9
Staff member
Moderator
Callsign
VE3
Evans956
Northern Virginia
2013 Explorer Base
So I was doing more research on this. I found out that you can enable fog lights in Forscan. I just want to know if there is a way to wire them to the Ford switch for this to work. It works on fiestas, and focuses
tbroecker01
West Bend, WI
2012 Explorer Base
I have been seeing severe different fog light kits on Ebay, some with harnesses and brackets, some just the lights, and so on.
My 2012 base does not currently have fog lights, but I want the factory look without the factory price.
Has anyone used the Ebay fog light kits?
If so, which one and from which seller?
Problems with installation or operation?
D Adding fog lights to 2016+ Base Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 43
T LED Fog Lights Modified 2011- 2019 Explorers - Tuning & Mods 25
M Fog lights 3000K Hid or yellow tint? Modified 2011- 2019 Explorers - Tuning & Mods 8
E H9 bulbs for fog lights? Modified 2011- 2019 Explorers - Tuning & Mods 0
T Fog Lights Rewire, need wiring diagram Modified 2011- 2019 Explorers - Tuning & Mods 2
B Fog Lights Modified 2011- 2019 Explorers - Tuning & Mods 3
M Headlight/Fog light upgrade for 2015 Explorer Sport Modified 2011- 2019 Explorers - Tuning & Mods 21
N Fog Light or High Beam Memory Modified 2011- 2019 Explorers - Tuning & Mods 9
D LED fog lamp upgrade? Modified 2011- 2019 Explorers - Tuning & Mods 30
mmartin028 Leak in my fog light housing. Modified 2011- 2019 Explorers - Tuning & Mods 2
S 2014 XSport Fog light took a rock.. Modified 2011- 2019 Explorers - Tuning & Mods 3
J HID/LED Headlamps and/or Fog Lamps - GO LIONS!! Modified 2011- 2019 Explorers - Tuning & Mods 3
7 Fogged fog light Modified 2011- 2019 Explorers - Tuning & Mods 3
M Fog light replacement recommendations Modified 2011- 2019 Explorers - Tuning & Mods 2
3 fog light projector retrofit Modified 2011- 2019 Explorers - Tuning & Mods 6
W Custom Headlights and Fog by RIHIDS Modified 2011- 2019 Explorers - Tuning & Mods 25
B Hoen H11 Fog Light Xenonmatch Modified 2011- 2019 Explorers - Tuning & Mods 1
M 2014 fog bulb out warning Modified 2011- 2019 Explorers - Tuning & Mods 1
R Another Fog Lamb bulb question Modified 2011- 2019 Explorers - Tuning & Mods 1
A HID Fog Install Questions Modified 2011- 2019 Explorers - Tuning & Mods 20
K Halo Headlight/Fog idea Modified 2011- 2019 Explorers - Tuning & Mods 44
J Fog light conversion Modified 2011- 2019 Explorers - Tuning & Mods 1
M Hood Pod Lights? Modified 2011- 2019 Explorers - Tuning & Mods 3
W JHO Rear Tailgate LED Lights Modified 2011- 2019 Explorers - Tuning & Mods 3
expoman55 Courtesy LED loading-dock Hatch lights Modified 2011- 2019 Explorers - Tuning & Mods 6
S Sylvania LED REAR TURN SIGNAL/Flasher and Back up Lights. Modified 2011- 2019 Explorers - Tuning & Mods 5
Rainlord How to access/open sidemarker lights Modified 2011- 2019 Explorers - Tuning & Mods 1
B 2016/2017 Smoke Tail lights? Modified 2011- 2019 Explorers - Tuning & Mods 11
A new led lights front bumper and headlights Modified 2011- 2019 Explorers - Tuning & Mods 3
M Off-road lights to front bumper Modified 2011- 2019 Explorers - Tuning & Mods 0
A changeing license plate lights to LED Modified 2011- 2019 Explorers - Tuning & Mods 3
F Aux Driving Lights - switch options Modified 2011- 2019 Explorers - Tuning & Mods 5
expoman55 Roof Lights Modified 2011- 2019 Explorers - Tuning & Mods 1
E Dome light wire - LED Grill lights Modified 2011- 2019 Explorers - Tuning & Mods 6
R LED back up, license plate & puddle lights Modified 2011- 2019 Explorers - Tuning & Mods 28
F New LED lights.... Modified 2011- 2019 Explorers - Tuning & Mods 5
T Foot-well/Under-dash Lights Modified 2011- 2019 Explorers - Tuning & Mods 6
M Automatic Lights on a Base Explorer Modified 2011- 2019 Explorers - Tuning & Mods 13
L Ghost Shadow Under Door LED Lights Modified 2011- 2019 Explorers - Tuning & Mods 11
R New member - No auto lights with TRS harness? Modified 2011- 2019 Explorers - Tuning & Mods 10
J Traffic control lighting/police lights options/opinions? Modified 2011- 2019 Explorers - Tuning & Mods 5
K Lights mods! Modified 2011- 2019 Explorers - Tuning & Mods 6
SurrealOne New head lights WOW Modified 2011- 2019 Explorers - Tuning & Mods 38
T wiring diagram for 2014 Explorer XLT brake and rear turn lights Modified 2011- 2019 Explorers - Tuning & Mods 1
C Make lights flash Modified 2011- 2019 Explorers - Tuning & Mods 3
1 Replacing 2nd and 3rd row dome/map lights in an Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
G how to upgrade interior lights for 2014 explorer Modified 2011- 2019 Explorers - Tuning & Mods 1
A License plate lights improved Modified 2011- 2019 Explorers - Tuning & Mods 3
T Anybody added aux reverse lights like this? Modified 2011- 2019 Explorers - Tuning & Mods 13
W 2011 FORD EXPLORER LED Lights from carid? Modified 2011- 2019 Explorers - Tuning & Mods 4
Similar threads
