Fog lights won't work | Ford Explorer - Ford Ranger Forums - Serious Explorations
jtexplorer
Location
58503
Bismarck, ND
1987 Bronco II
Hey everyone, I recently picked up a 2010 Explorer XLT V6. I honestly didn't even realize it had fog lights until I was changing the oil yesterday. But it really didn't make a difference when I realized I had them, because they don't work anyway.
I am good with electronics, and I think I have the issue traced back to the headlight switch, but I don't have diagrams available. So much of newer vehicles are computer-controlled that I would appreciate any first-hand experience with my problem.
Here's how my troubleshooting has gone so far:
-I put an ohmmeter across the fuse, and it is good.
-I jumped (bypassed) the relay, and the fogs turned on, so I know the bulbs are good and the wiring between the lights and the relay is all good.
-I put an ohmmeter across the normally open relay terminals as I applied power to the relay's coil terminals, and the relay activated and closed the terminals, so I know the relay is good.
-I took the headlight switch out of the dash and, using an ohmmeter, I was able to find the pin used to control the relay. I used an ohmmeter between the hot pin and the fog relay pin as I cycled the switch, and there was no change whether the switch was engaged or not. This led me to blame the switch. However, when I jumpered between the hot pin of the connector and the fog relay pin, nothing happened. I have no idea why. I think that putting 12v to the wire leading to the relay should cause the fogs to turn on. I tested resistance between the negative side of the relay coil and the negative battery post, and it showed good connectivity. I did have the headlight fuses pulled so I didn't drain my battery as I was troubleshooting. Could this have caused the foglights to not work somehow?
Tell me what I'm missing! I'm inclined to buy a new switch because it is not too expensive, and the switch is the only component in the circuit that I was unable to verify as good.
Thanks in advance for any help.
- Joe
ronwc
Largo, FL
2008 XLT
Not trying to be a smartass or anything, but you do realize that you have to turn the headlights on first then pull switch out to turn on foglights.
jtexplorer
Location
58503
Bismarck, ND
1987 Bronco II
Yes I knew the headlights have to be on in low beams.
What I didn't realize is that the engine has to be running. I feel like a moron, but at least my issue is resolved.
Feel free to delete thread, unless you think my troubleshooting procedure could be beneficial.
- Joe
JeepGuy25
2010 Ford Explorer E.B.
Haha dude dont feel bad. When I first bought my explorer I took it straight from the Tag place to get inspection for my state. When it was idling during the emissions check, I noticed one of the fogs was burned out. While it was on the lift, I went to take the bulb out, and saw that the plug was off, and some wiring modifications were done. So I plugged it in, went to the switch and turned them on, nothing. Neither side worked. Then I thought I blew something out by plugging the light back in due to the hacked wiring.
Later I realized that when I tried them the second time the key was off haha. Its kind of set up weird that way. Huge relief when I realized I didnt have to chase wiring gremlins haha.
J.
