slow-demon
- September 28, 1999
- Hawaii
- '91 xl sport
Do any of you guys with the skjacker 6" lift experience any type of axle wrap? I have a '91 explorer with a superlift 5.5" lift that uses the spring over axle conversion. The rear springs are sagging again. I installed a add-a-leaf a while back to try and aleviate the sagging rear. It worked for a while but the rear is sagging again. I am also experiecing a lot of axle wrap since the rear springs are too soft. I ask you skyjacker owners because the lift you use uses new rear springs while still using the under axle mounting postion. I am thinking the skyjacker rear springs are less apt to cause axle wrap.
