rch10007
- August 16, 2006
- Clarksville, TN
- 2004 Limited 4.6L
I have a 2002 EB Explorer, 4x4, 4.0L blah blah...
I have had the annoying squeak, squeal, bird chirp, tick, and whatever other term that's been used to described this freakin issue for a long time, like over 4 years!!!!!
I have read every single fix that has been posted on every forum I could find with "tick or squeal or squeak" in the body or title. Well, today I was messing with it again since it's below freezing and I love working on my truck in the ice and snow while slipping around on the ice in the driveway!
I took a furring strip and stuck it down into the motor, while it IS running, and placed it against the water pump pulley. Nothing happens at first, but then I bump it against the belt while it's spinning and BAM - no noise!!!!!!!!!!
SO, I am excited to know that I have pinpointed the issue BUT now the question is what the hell to fix?
What does this tell you?
While the motor is running, placing a piece of wood against the pulley and against the belt and it stops chirping squealing squeaking or whatever...
The noise will NOT STOP if I place the wood against any other pulley so that must mean there is something to the water pump OR the pulley itself.
Well, given this info, what do you think?
The only other thing I found while the belt was off is the alternator. I rotated the pulley and it did make a high pitch noise BUT I hesitated to pull it since so many have before me to no avail!
I am amazed by this new found info and eagerly wait to hear what you think!!!
