steveissteven
- December 31, 2000
- LAS VEGAS, NEVADA
- '93 SPORT
According to the Hanes Manual, fuel pressure at idle with vacuum attatched to FPR (Fuel Pressure Regulator) should be between 30-45 psi
THIS IS INCORRECT!!!
Proper fuel pressure should be between 35-45 psi
Anything less and your running LEAN causing for loss in power and high fuel consumption. This is due to the fact that the onboard computer is having to compensate for a lean condition, thus increases the PULSE WIDTH of the fuel injectors; ultimately burning more fuel.... Hence poor fuel economy, poor idle, and loss in power.
NEVER EVER REPLACE YOUR FUEL PUMP WITH AN AFTERMARKET PUMP... IT WILL FAIL AND ULTIMATELY IT WON'T BE ABLE TO DELIVER THE REQUIRED 35-45 PSI AS REQUIRED BY FORD SPECS
This applies to all trucks and suv's
