Ford A X Z plan pin numbers. For U S only.
Michael W
18 Explorer Platinum
How would you apply it at the dealer?
dkean
Location
Mays Landing
south Jersey
2018 Explorer XLT 3.5 V6
If you request an X plan pin number from me I enter your information on the Ford web site. Then Ford generates a pin number and sends it to me and you. When you receive your X plan pin number from Ford you print it out and take it to your Ford or Lincoln dealer and buy one off the lot or you can order one. This all happens as fast as I can type and hit send.
chartquist
Memphis, TN
2016 Explorer Sport
I have a buddy at Ford and used this process. Simple, painless and saved thousands of dollars. Zero haggling too. @dkean , it is very generous and classy to offer this to the forum!
Michael W
Ugh....Wish I knew this before I placed my order.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
If I recall, there are a few posts where members said they were able to get a better deal without using X plan.
dkean
Location
Mays Landing
south Jersey
chartquist I lived in Memphis in 1947. Went to kindergarten there. Then we moved back to Connecticut.
Michael W
I would have liked a Z plan number. My deal is better than X.
dkean
Location
Mays Landing
south Jersey
My wife and I will be buying a new explorer later this year. Maybe a 2018 or a 2019. We get the Z plan. I worked at Ford from 1964 to 1975. You had to have ten years to be vested in the pension plan. My daughter and son in law get get a new ford every three years plus my son in law has a F250 super duty 6.0. My family gets the Z plan also.
Michael W
My wife and I will be buying a new explorer later this year. Maybe a 2018 or a 2019. We get the Z plan. I worked at Ford from 1964 to 1975. You had to have ten years to be vested in the pension plan. My daughter and son in law get get a new ford every three years plus my son in law has a F250 super duty. My family gets the Z plan also.
I'm available for adoption.
peterk9
Staff member
Moderator
Callsign
VE3
If you're thinking about a 2019, which will likely be a short production model, why not hang in there and see what the redesigned and reported RWD 2020 looks like?
dkean
Location
Mays Landing
south Jersey
Peter I am thinking of the 2020. Waiting to see more pictures.
new to ford
Rochester Hills, MI
11XLT202A 17Sport401A
I bought a '17 on Dec'17 and was able to get a better deal outside of x-plan, which I could have gotten through my neighbor.
A Thoughts On "FORD PROTECT" Extended Service Plan? Stock 2011 - 2019 Ford Explorer Discussion 22
M Ford Premium Maintenance Plan Question Stock 2011 - 2019 Ford Explorer Discussion 1
J 2018 Ford Explorer Lift Gate Stock 2011 - 2019 Ford Explorer Discussion 0
M New here. Just took my 2011 Ford Explorer XLT to the dealer here in Columbia SC, and they wouldn't honor a recall for my power steering problem. Stock 2011 - 2019 Ford Explorer Discussion 1
D 13 Ford Explorer Light Module Location Stock 2011 - 2019 Ford Explorer Discussion 3
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 13
L 2012 Ford Explorer Ambient Lighting Wiring Stock 2011 - 2019 Ford Explorer Discussion 3
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
M Where are you buying Ford parts during COVID-19? Stock 2011 - 2019 Ford Explorer Discussion 2
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
P 2017 Ford Explorer Limited drivers side LED fog light has quit working Stock 2011 - 2019 Ford Explorer Discussion 2
B 2017 Water Pump? New to Ford forum. Stock 2011 - 2019 Ford Explorer Discussion 16
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
G 2012 Ford Explorer blower motor resistor Stock 2011 - 2019 Ford Explorer Discussion 4
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
G 2014 Ford Explorer low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
M 2018 Ford Explorer XLT 3.5L. Right side engine bay whine/whistle noise Stock 2011 - 2019 Ford Explorer Discussion 14
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
B 2014 Ford Exployer Sport Leak in passenger floor board Stock 2011 - 2019 Ford Explorer Discussion 4
J 2018 Ford Explorer XLT horn issue Stock 2011 - 2019 Ford Explorer Discussion 4
R APIM reset for Ford Escape Stock 2011 - 2019 Ford Explorer Discussion 3
C 2015 Ford Explorer Keeps blowing interior light #12 fuse. Stock 2011 - 2019 Ford Explorer Discussion 2
E Spring like sound after Ford´s toe link recall update Stock 2011 - 2019 Ford Explorer Discussion 4
D About to join the Ford Explorer Sport family.. Stock 2011 - 2019 Ford Explorer Discussion 7
A 2016 Ford Exploer Sport LED Foglights Stock 2011 - 2019 Ford Explorer Discussion 2
U Contribute your experience: Ford Explorers 2016-2019 Stock 2011 - 2019 Ford Explorer Discussion 11
R 2018 Ford Explorer Sport electrical issues Stock 2011 - 2019 Ford Explorer Discussion 2
D Gas Additive for Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 6
T Disappointed With Ford Sevice Stock 2011 - 2019 Ford Explorer Discussion 16
F Rear Climate Control Cuts Out...Ford Unable To Diagnose Stock 2011 - 2019 Ford Explorer Discussion 6
mattadams Back in a Ford Explorer after years away! Stock 2011 - 2019 Ford Explorer Discussion 4
M 2013 Ford Explorer Dash Noise\Grinding-Not a blend door I think Stock 2011 - 2019 Ford Explorer Discussion 3
O 2012 Ford Explorer ignition lock reset Stock 2011 - 2019 Ford Explorer Discussion 3
J Ford Dealer uses rubber band to fix issue Stock 2011 - 2019 Ford Explorer Discussion 10
B Ford knowingly sold two vehicles with faulty transmissions. Stock 2011 - 2019 Ford Explorer Discussion 4
G $$$ Dollar Value of 2017 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 5
K How Ford Lost a New Customer Stock 2011 - 2019 Ford Explorer Discussion 9
P 2015 Ford Explorer Limited stalling at intersections/idle Stock 2011 - 2019 Ford Explorer Discussion 4
T Ford ESP owner with rental coverage- loaners provided during service? Stock 2011 - 2019 Ford Explorer Discussion 14
N Ford Explorer 2016 AC not working grey out Stock 2011 - 2019 Ford Explorer Discussion 10
G 2013 Ford Explorer XLT Rear camera replacement Stock 2011 - 2019 Ford Explorer Discussion 13
D 2017 Ford Explorer Sport stock exhaust Stock 2011 - 2019 Ford Explorer Discussion 10
L Unnecessary Repairs mandated by Ford Stock 2011 - 2019 Ford Explorer Discussion 14
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
expoman55 Ford support members of this forum Stock 2011 - 2019 Ford Explorer Discussion 7
J Great Experience with Larry Miller Ford Lakewood, Colorado Stock 2011 - 2019 Ford Explorer Discussion 6
J 2018 Ford Explorer XLT outlets Stock 2011 - 2019 Ford Explorer Discussion 2
S Warranty on Ford Battery? 2016 Exp Sport Stock 2011 - 2019 Ford Explorer Discussion 34
Similar threads
