Ford ESP Question
1stXLT
Columbus, OH
2017 XLT
202A, Tech pkg
I'm wondering if there is a website or other venue to view/confirm my ESP coverage? I searched through the forum and saw many posts related to ESP coverage but did not see any relating to a way to confirm coverage so I apologize if I missed it.
Part of my negotiation was 5yrs/75k ESP coverage thrown in at no cost to seal the deal. I have the contract, and that may be all I need, but everything else is view able on-line so I'm just wondering if the ESP can be viewed on line as well.
Thanks
EDIT: my ESP is the premium coverage
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Your dealer can show you in OASIS when they plug your VIN in. There is no online tool.
bdginmo
St. Louis
2017 Explorer Platinum
You can call Ford customer service, but another way I have found (posted on another forum) is to go to the Ford Protect website and try to get a quote. You'll have to type in your VIN. If you don't have an ESP attached to that VIN it will happily give you a quote. If there is an ESP already registered it will give you a vague error message.
1stXLT
Columbus, OH
2017 XLT
202A, Tech pkg
Thanks for the info. I did try going to the Ford Protect site and it gave me a cryptic error message so I guess I'm good to go. Just to double check I'll have them run my VIN through the OASIS system as blwnsmoke suggested when I go in for my first oil change. :)
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
Yes, check OASIS. If you PM me your VIN I can also take a look as well, I can see some limited data.
1stXLT
Columbus, OH
2017 XLT
202A, Tech pkg
Thanks. Will do.
P Question for Florida residents about Ford ESP Stock 2011 - 2019 Ford Explorer Discussion 1
T Ford ESP owner with rental coverage- loaners provided during service? Stock 2011 - 2019 Ford Explorer Discussion 14
M Ford ESP Warranty or Not? Stock 2011 - 2019 Ford Explorer Discussion 7
L The Value of the Ford ESP Extended Warranty Stock 2011 - 2019 Ford Explorer Discussion 9
blwnsmoke Ford ESP at dealer cost to forum members Stock 2011 - 2019 Ford Explorer Discussion 150
S Ford ESP and Dealership driving me nutz Stock 2011 - 2019 Ford Explorer Discussion 7
blwnsmoke 2015 Ford ESP Changes Stock 2011 - 2019 Ford Explorer Discussion 20
Flounder Ford Extended Service Plans (ESP) Stock 2011 - 2019 Ford Explorer Discussion 587
D 13 Ford Explorer Light Module Location Stock 2011 - 2019 Ford Explorer Discussion 3
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 8
L 2012 Ford Explorer Ambient Lighting Wiring Stock 2011 - 2019 Ford Explorer Discussion 3
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
M Where are you buying Ford parts during COVID-19? Stock 2011 - 2019 Ford Explorer Discussion 2
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
P 2017 Ford Explorer Limited drivers side LED fog light has quit working Stock 2011 - 2019 Ford Explorer Discussion 2
B 2017 Water Pump? New to Ford forum. Stock 2011 - 2019 Ford Explorer Discussion 16
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
G 2012 Ford Explorer blower motor resistor Stock 2011 - 2019 Ford Explorer Discussion 4
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
G 2014 Ford Explorer low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
M 2018 Ford Explorer XLT 3.5L. Right side engine bay whine/whistle noise Stock 2011 - 2019 Ford Explorer Discussion 12
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
B 2014 Ford Exployer Sport Leak in passenger floor board Stock 2011 - 2019 Ford Explorer Discussion 4
J 2018 Ford Explorer XLT horn issue Stock 2011 - 2019 Ford Explorer Discussion 4
R APIM reset for Ford Escape Stock 2011 - 2019 Ford Explorer Discussion 3
C 2015 Ford Explorer Keeps blowing interior light #12 fuse. Stock 2011 - 2019 Ford Explorer Discussion 2
E Spring like sound after Ford´s toe link recall update Stock 2011 - 2019 Ford Explorer Discussion 4
D About to join the Ford Explorer Sport family.. Stock 2011 - 2019 Ford Explorer Discussion 7
A 2016 Ford Exploer Sport LED Foglights Stock 2011 - 2019 Ford Explorer Discussion 2
U Contribute your experience: Ford Explorers 2016-2019 Stock 2011 - 2019 Ford Explorer Discussion 11
R 2018 Ford Explorer Sport electrical issues Stock 2011 - 2019 Ford Explorer Discussion 2
D Gas Additive for Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 6
T Disappointed With Ford Sevice Stock 2011 - 2019 Ford Explorer Discussion 16
F Rear Climate Control Cuts Out...Ford Unable To Diagnose Stock 2011 - 2019 Ford Explorer Discussion 6
mattadams Back in a Ford Explorer after years away! Stock 2011 - 2019 Ford Explorer Discussion 4
M 2013 Ford Explorer Dash Noise\Grinding-Not a blend door I think Stock 2011 - 2019 Ford Explorer Discussion 3
O 2012 Ford Explorer ignition lock reset Stock 2011 - 2019 Ford Explorer Discussion 3
J Ford Dealer uses rubber band to fix issue Stock 2011 - 2019 Ford Explorer Discussion 10
B Ford knowingly sold two vehicles with faulty transmissions. Stock 2011 - 2019 Ford Explorer Discussion 4
G $$$ Dollar Value of 2017 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 5
K How Ford Lost a New Customer Stock 2011 - 2019 Ford Explorer Discussion 9
P 2015 Ford Explorer Limited stalling at intersections/idle Stock 2011 - 2019 Ford Explorer Discussion 4
N Ford Explorer 2016 AC not working grey out Stock 2011 - 2019 Ford Explorer Discussion 10
G 2013 Ford Explorer XLT Rear camera replacement Stock 2011 - 2019 Ford Explorer Discussion 13
D 2017 Ford Explorer Sport stock exhaust Stock 2011 - 2019 Ford Explorer Discussion 10
L Unnecessary Repairs mandated by Ford Stock 2011 - 2019 Ford Explorer Discussion 14
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
expoman55 Ford support members of this forum Stock 2011 - 2019 Ford Explorer Discussion 7
Similar threads
