ExplorerUSA
- November 12, 2012
- Lexington, KY.
- 2011-Up Ford Explorer
Just a quick note to let everybody know that if you are interested into installing a grille guard for the 2011-Up Ford Explorer of the following installation issue. You will have to cut out a small notch in the lower front splash guard to properly install the mounting brackets to the body frame. It is very important that you only cut out a notch just barely large enough to insert the grille guard mounting brackets through the lower splash guard.
