jlnjl
- May 16, 2012
- Terre Haute, In
- 2003 Ford Explorer V8
I have A 2003 Ford Explorer V8 Im having problem with it idling problems. First I have changed the Idle Air control valve twice. I start up engine runs 2000 rmps then goes to 800 rpms which is good but if you rev the engine to above 2000 it stays there and will not come down.. if i put in gear it go down the road at 2000rmp. if I come to stop it will findly come down but as so as i push the gas it revs up to 2000Rpm again.. I have clean the throttle with carb cleaner also.. I need help please...
