2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Background
When other forum members describe their performance issues I frequently suggest that they replace their fuel filter if due and check their fuel pressure. Yesterday Harbor Freight Tools offered their fuel pressure test kit for $10 so I bought one. The following procedure is the result of me trying out my new test kit.
In 1999 Ford switched from a return fuel system with a rail mounted fuel pressure regulator (FPR) to a returnless fuel system with a rail mounted fuel pressure damper and a tank installed FPR. My 2000 Explorer shop manual states that the fuel pressure for the returnless system should be 65 psi +/- 8 psi.
Test Procedure for pre 1999 return fuel system
1. Locate the fuel pressure test port on the engine as identified in the photo below.
2. With the engine ignition switch Off insert one end of the test kit fuel pressure hose into a container and connect the other end to the valve to relieve the existing pressure as shown below.
3. Remove the container and attach the gauge to the free end of the hose. Wrap the connection fittings with a rag to catch any leaks as shown below.
4. Turn the ignition switch to On and then off. The fuel pump will only run for a few seconds since the engine was not started.
5. Check for leaks at all of the fittings and tighten fittings as required. In my case it was necessary to use Teflon tape at the hose to gauge connection to prevent leakage. Leakage is indicated by a rapid reduction in the fuel pressure reading on the gauge.
6. Start the engine and record the pressure at idle. It should be 30 to 45 psi.
7. Slowly increase the engine speed to 3000 rpm while watching the pressure. The pressure should increase slightly as the engine speed increases because the vacuum decreases. Record the pressure and then let the engine idle.
8. Very rapidly increase the engine speed while watching the pressure gauge. The pressure should increase significantly while the engine speed is increasing since the vacuum drops significantly.
9. Turn off the engine and watch the pressure gauge. The pressure should not drop below 30 to 65 psi in 5 minutes.
10. Disconnect the vacuum line to the fuel pressure regulator and plug the line to prevent a leak. I plugged mine with a vacuum gauge as shown below.
11. Start the engine and record the fuel pressure at idle with no vacuum to the regulator. It should be 40 to 50 psi.
12. Compare the recorded pressure gauge readings. The pressure at idle with no vacuum should be the greatest. The pressure at idle with vacuum should be the least. The pressure at 3000 rpm should be between the idle readings.
