Ford Explorer second generation Upgrade to Digital Cluster | Ford Explorer Forums - Serious Explorations
Lviv
95 Limited
HI all, this is short photo report of Digital cluster installed in Ford Explorer second generation. Sorry for english and short text - I from Ukraine.
I searching cluster with same dimensions and design. And stopped on cluster from Mercury Villager 1997.
For make it You need Time, and:
1. digital cluster
2. two mini 12V relay
3. transistor E13003
4. 400-500 ohm 0.5 - 1 Watt resistor
5. pigtails from new cluster
6. keypad from cluster
7. new indicators decals printed on matte vinyl.
8. Temperature Sender STANDARD MOTOR PRODUCTS Part # TS321 + adapter custom made. (for read correct temperature on cluster)
9. Ambient Air Temperature Sensor Connector STANDARD MOTOR PRODUCTS Part # HP4400
10. Ambient Air Temperature Sensor STANDARD MOTOR PRODUCTS Part # TX12
I lost 3 week /2-3 hours per day.
First You need cuted mounting holes from your original cluster and glued to new cluster body.
next, I removed glass from old cluster face and modified this face for new cluster.
I add two indicators in left and right side. Now You have in left indicator Reset Fuel next low battery, low oil level i changed to THEFT and low washer fluid to 4WD and 4LO.
You must erase from glass old indicator logos and add new.
Inverted low oil pressure signal - use relay
Inverted cruise on signal - use relay
Inverted Air bag indicator - need some changes in parts soldering.
Inverted dimming feed signal - transistor E13003 see pic
I add second temperature sensor (same to ATC and ENGINE COOLING to computer) for cluster and installed to standard place outside temperature sensor. and old sensor moved inside on car under dash panel. now in cluster I read outside temperature and in top panel inside temperature.
I connected fuel flow signal to instrument cluster, but it list incorrect only 3-10 l per
100km.
cluster and keypad i cover by 3M brushed SS vinil decal.
I hope it help.
Link to my facebook with pics
https://www.facebook.com/100004997201676/posts/470982373078332/?pnref=story
and to pics from facebook
https://scontent-fra3-1.xx.fbcdn.ne...=12c549fc7914ed9b2ee82ed2aad9ba50&oe=55F532D2
https://scontent-fra3-1.xx.fbcdn.ne...=568dbdcab24521253d4aebb0b907d812&oe=55E7305F
https://scontent-fra3-1.xx.fbcdn.ne...=61ce49283861486174fd8f7fd030647a&oe=55EBCBFF
https://scontent-fra3-1.xx.fbcdn.ne...=d97214996e349effdd528b059188d13b&oe=55F17291
https://scontent-fra3-1.xx.fbcdn.ne...=c0f60af21ec5569900997f063088bbce&oe=55EDC145
https://scontent-fra3-1.xx.fbcdn.ne...=b23e52a6b6f2f340ba91a54dee6c6426&oe=562B58BD
https://scontent-fra3-1.xx.fbcdn.ne...=5857e111908585061252b39fed52dc07&oe=55F2456A
https://scontent-fra3-1.xx.fbcdn.ne...=c10ead4a660c4f1e2253bc65fe3da05f&oe=56254453
https://scontent-fra3-1.xx.fbcdn.ne...=f20220659eeab6bf59ad0b67b7f21957&oe=55F77559
https://scontent-fra3-1.xx.fbcdn.ne...=3ac4362aeac00d60f83f54b180c5970b&oe=562A437A
https://scontent-fra3-1.xx.fbcdn.ne...=79fde179aed8ea68f323d5a0089763ef&oe=5632F54E
https://scontent-fra3-1.xx.fbcdn.ne...=1cb8c17096388da0bc02ea504b4bff11&oe=55F80221
https://scontent-fra3-1.xx.fbcdn.ne...=b4f7af7ba65fdd956e040826a8186402&oe=562799D6
https://scontent-fra3-1.xx.fbcdn.ne...=026e039411e1ae42a5ebbaa14f67662a&oe=5634B098
https://scontent-fra3-1.xx.fbcdn.ne...=e214fe27fe00d9c2a1f21384cbb799a1&oe=56345F72
https://scontent-fra3-1.xx.fbcdn.ne...=e39e4217ea710b8da9320c2f9df1cf71&oe=55FA13B9
https://scontent-fra3-1.xx.fbcdn.ne...=521abe21a1b214ca72ff48df29c77007&oe=56262BD5
https://scontent-fra3-1.xx.fbcdn.ne...=ed0a0df4b5a61cb5dcb7f737a3dd19cd&oe=56330265
https://scontent-fra3-1.xx.fbcdn.ne...=8109356ca9335ab41118a731e3a51bdf&oe=56283246
https://fbcdn-sphotos-g-a.akamaihd...._=1441999208_0b8a26b8d3be35dada6a26fd310dc81b
https://scontent-fra3-1.xx.fbcdn.ne...=677768485b78ecfe482c9255063b9563&oe=56347011
https://scontent-fra3-1.xx.fbcdn.ne...=ff0a8876909d9b909bff8d754b71d20d&oe=55F13068
https://scontent-fra3-1.xx.fbcdn.ne...=b2930c07c943fa4a7e17fdaa07ae85c6&oe=55F08E9B
https://scontent-fra3-1.xx.fbcdn.ne...=414567984b0d9d24791faee7448e44a6&oe=55F212D1
https://scontent-fra3-1.xx.fbcdn.ne...=2879f70ed5c859b524c384f3dea367f3&oe=562AF16E
https://scontent-fra3-1.xx.fbcdn.ne...=763af70e2eb592f3ad021f8b52080366&oe=55E89034
https://scontent-fra3-1.xx.fbcdn.ne...=7cee678a9bea29f17a7ca0185a2b45ae&oe=55F4F910
https://scontent-fra3-1.xx.fbcdn.ne...=073e4defeae6235cb1a2ac3c92b37b0b&oe=56281284
https://scontent-fra3-1.xx.fbcdn.ne...=6fd4ae690e368dab4347b81fa17f1735&oe=562E63EB
https://scontent-fra3-1.xx.fbcdn.ne...=21dfe015c06276e90a2623b82ee7323e&oe=562F6083
https://scontent-fra3-1.xx.fbcdn.ne...=44a3a9b4ef839628a6669b48c1719214&oe=56249BB8
https://scontent-fra3-1.xx.fbcdn.ne...=317f9634350762997acaff68d0fc1965&oe=55F1456A
https://scontent-fra3-1.xx.fbcdn.ne...=30bb039f0bf697fb00c55455fbd1e87b&oe=55E93B18
https://scontent-fra3-1.xx.fbcdn.ne...=f2e8375efb9d2faecf8f3e1b84e85b1c&oe=55E72387
https://scontent-fra3-1.xx.fbcdn.ne...=3a688d8c4f4ff570b196cc09dadd2ff3&oe=55F5A454
https://scontent-fra3-1.xx.fbcdn.ne...=c1c01f6fb64768dedb98a53b0d991290&oe=55EBC752
Dang, that really looks good!
Ya...very nice work.
Fantastic work. It looks REALLY cool!!
Definitely a mod I would enjoy to do. Thanks!
WOW! That's very impressive :thumbsup:
Dang that is sweet! Make a plug and play setup and I'll buy it!
I'm trying to understand this. Do you have any details on the wiring? Color coding documented? Did you have the new logo's printed yourself?
It looks absolutely awesome by the way. Beautiful way to update an interior.
Hi, i will post explorer and villager wiring diagrams in morning and I print logos in advertising printing house.
thanks
Roman
That is definitely the best interior upgrade I have seen yet. Outstanding work.
ok,
explorer diagrams
link to facebook
https://www.facebook.com/100004997201676/posts/471945882981981/?pnref=story
and to pics
https://scontent-fra3-1.xx.fbcdn.ne...=0062d2da0b055511bd3fd660e142db57&oe=5632A242
https://scontent-fra3-1.xx.fbcdn.ne...=c1be6839db8104c8ec9146fa46e3f446&oe=562D9B29
https://scontent-fra3-1.xx.fbcdn.ne...=5b853c275872896c2c359fe2a18e0b68&oe=55F29DC0
https://scontent-fra3-1.xx.fbcdn.ne...=14b7a6909dbfe314691b32a082ea2e4d&oe=55ED9B27
https://scontent-fra3-1.xx.fbcdn.ne...=73962d28234dcf744dfb053eb8cc7b7e&oe=55EE3D9D
https://scontent-fra3-1.xx.fbcdn.ne...=96e7d2b36fc29438b9254d2974ca9991&oe=55F8516F
https://scontent-fra3-1.xx.fbcdn.ne...=e47b26b9801542540b224e356e8e034c&oe=562294F8
https://scontent-fra3-1.xx.fbcdn.ne...=9d089a60859b2e86efcea6e9485f59c8&oe=5622513C
https://scontent-fra3-1.xx.fbcdn.ne...=0750fb59ae16b1ded694d6d1d55038d4&oe=55EF73BF
https://scontent-fra3-1.xx.fbcdn.ne...=8e2e17f5cabe1f24dc0300eaf52b1d39&oe=562B6B66
https://scontent-fra3-1.xx.fbcdn.ne...=69cb2270833fe074734d375b5ffbcec4&oe=55E84E25
https://scontent-fra3-1.xx.fbcdn.ne...=8145359577e3daf5195d1dcf29f35af1&oe=55F60A4D
https://scontent-fra3-1.xx.fbcdn.ne...=bf85712d74a2f85112e1a36f86fdc834&oe=55F7D8D1
https://scontent-fra3-1.xx.fbcdn.ne...=013a0263b87bc98f2bb98eb8c6d60ad4&oe=562D56EE
https://scontent-fra3-1.xx.fbcdn.ne...=0ba1f6361ad8a05780e1e60cdcbd62a9&oe=56302CD9
Villager diagrams
link to facebook
https://www.facebook.com/100004997201676/posts/471949392981630/
to pics
https://fbcdn-sphotos-d-a.akamaihd...._=1445795207_1acb7314f9b2c5afe3d732c9171b5835
https://scontent-fra3-1.xx.fbcdn.ne...=6ad3a12db5d1a4737f492225b2983695&oe=56249019
https://scontent-fra3-1.xx.fbcdn.ne...=a432fec4a0d8e8de04fc76907323b4a1&oe=562E1FBE
https://scontent-fra3-1.xx.fbcdn.ne...=7960841a475e556ec348fa61c27db31f&oe=5629314F
https://scontent-fra3-1.xx.fbcdn.ne...=add91fcd5b7789bab66cffdbb59419ed&oe=55F7EF4D
https://scontent-fra3-1.xx.fbcdn.ne...=d6595ad5a7a49d024d77cacc88c68d74&oe=56299742
https://scontent-fra3-1.xx.fbcdn.ne...=6c671ecc3ab201d20d2535ed9a6bdea0&oe=5630F82C
https://scontent-fra3-1.xx.fbcdn.ne...=1deb2c08a6584025b5abe1aab185d750&oe=56333FDC
https://scontent-fra3-1.xx.fbcdn.ne...=4e43bd8be0428ed1414a81d50360fec3&oe=5630B7B7
https://scontent-fra3-1.xx.fbcdn.ne...=0908452fb8e957204395b653778ae7d6&oe=5630CD3B
https://scontent-fra3-1.xx.fbcdn.ne...=16164cd6cdc2124d4d049220aae3c7d4&oe=55F75059
https://scontent-fra3-1.xx.fbcdn.ne...=4d1bb0d06c99720047bf8b902ccddf84&oe=56248067
https://scontent-fra3-1.xx.fbcdn.ne...=baf93c1a568523ef857ee0904a925291&oe=5634749F
https://scontent-fra3-1.xx.fbcdn.ne...=f8fa10bd00112aa6c0b1dfe06110edd8&oe=55EA29BF
to pics from hardcopy with my notes
https://scontent-fra3-1.xx.fbcdn.ne...=d6f2fb6286a8ddd0b19663dbc64a4b3d&oe=55F2B25A
https://scontent-fra3-1.xx.fbcdn.ne...=d94bef85f745f9a3bb23f2c6315fa332&oe=56235AF0
https://scontent-fra3-1.xx.fbcdn.ne...=61073962ec3c7ecf483fc5f822d6d54a&oe=5626A6F1
https://scontent-fra3-1.xx.fbcdn.ne...=542fa125edd90c43650da8cae832c4b3&oe=562791D1
https://scontent-fra3-1.xx.fbcdn.ne...=db46c8ffe5666670d0507215abdfcaa6&oe=55F5DC4B
https://scontent-fra3-1.xx.fbcdn.ne...=603a44c72c08d8ae3238aea04988df1b&oe=55EB2EB9
thanks
Roman
I've been working on this on and off since I saw this mod. I've got all of the cluster mounts and the faceplate mods done. Working on the electronics mods now. I have everything done except for the dimmer invert mod.(waiting on transistor, had to order) I'm working on an idea to make it more plug and play, so that there's no need to cut your trucks cluster harness. That was the big thing for me, having the ability to go back if the new cluster were to fail. Once I have that done I'll post up some pics of the harness and any wiring mods.
Looking forward to the pics of the install and final product!
If You will make plug and play, maybe some troubles with free space.
Wow! That's very nice, great job!!
That is awesome, if I had the patience I would totally do this mod. It looks great and very clean!!
