edcosta
- September 8, 2016
- 2003 Explorer Limited v8
I have a 03 Explorer limited v8, the cold AC is not working and the fuse #10 (AC clutch contact) under the dash in driver side keeps blowing every time I turn the AC on. If the AC is off it does not blow.
I had the car serviced at a Ford dealer for weeks and they could not figure out why the fuse is blowing.
I am looking at all forums and the whole internet trying to figure it out myself. I came across a post where I learned that testing the alternator by removing the negative cable of the battery with the engine running can be catastrophic. I didn't now that and before the AC stopped working I tested my alternator that way (stupid, I know...), now I am linking this test with the AC issue.
I also learned that a faulty diode can cause the AC to blow fuses, but it is something very rare to happen and because of that most of the mechanics don't check the diode.
This car have a specific diode for the AC clutch. So I am about to go ahead and change it, but apparently only Ford sells that.
I don't have the knowledge and tools to test the diode myself. So I would just go ahead and change it and see if it works, but I would like your opinions before.
Does the this faulty diode theory makes sense?
