Ford of Japan Mods
Black Mounty
New York, New York
2011 Explorer XLT
I was taking a look at Ford of Japan's Explorer Website. They have some pretty coold mods available, but the cost of these items is a bit high when you plug in the yen to US $ ratio. Most interesting is the HID lighting unit and some other interesting items. The Nav System is pretty coll as well. Anyone have an idea of importers or parts sources?
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
some links would be nice
-Drew
Black Mounty
New York, New York
2011 Explorer XLT
cwescapexlt4x4
Explorin' the Desert SW
Litchfield Park, AZ area...
2016 Explorer LTD (FWD)
Wish i could get the export tail lamps with the yellow signals and the reflective strip in the reverse sensor area... that would be nice..
Too bad i can't read japanese... :confused:
KKM
Kansas City
Ford Performance
The Japanese do like to modify Explorers! Our 04-Up True-Rev Sport Induction Kit get's shipped to Japan quite a bit, in fact the demand in that market vs the US is about 6-1.
A 2008 Ford Explorer rough downshift Stock 2006 -2010 Explorers 2
T 2006 Ford Exployer 4X4 Stock 2006 -2010 Explorers 8
A First time transmission oil and filter change safe on my 2008 Ford Explorer V8 2x4 limited with 109,000 miles ? Stock 2006 -2010 Explorers 13
T 2006 ford explorer fuel pump wiring Stock 2006 -2010 Explorers 0
E Few updates: one Explorer gone, one crossed 300,000 mark, a "new" Ford in the family. Stock 2006 -2010 Explorers 10
J 2006 Ford Explorer Stock 2006 -2010 Explorers 2
A 2008 Ford Explorer 4x4 V8 with 135,000 miles worth buying ? Stock 2006 -2010 Explorers 24
K Ford explorer wiring help Stock 2006 -2010 Explorers 0
C 2007 Ford Explorer 100$ bounty Stock 2006 -2010 Explorers 12
W 2009 Ford Explorer Stock 2006 -2010 Explorers 6
T 2007 Ford Explorer limited “Ironman edition” Stock 2006 -2010 Explorers 4
C 2010 Ford Explorer Eddie Bauer 4.0L Stock 2006 -2010 Explorers 0
V 2010 Ford Explorer 4.0L with stuck open injectors Stock 2006 -2010 Explorers 2
S 2006 Ford Explorer Transfer case vent hose Replacement Stock 2006 -2010 Explorers 3
R 2007 Ford Explorer Eddie bower gas gage Stock 2006 -2010 Explorers 3
B Ford Emblem Stock 2006 -2010 Explorers 7
R 2009 Ford Explorer Stock 2006 -2010 Explorers 6
2 How long do you think my 2010 Ford Explorer will last? Stock 2006 -2010 Explorers 20
H Found the 05/06 ford factory service manual/program Stock 2006 -2010 Explorers 1
T Just got a new Ford Explorer... Stock 2006 -2010 Explorers 13
H 2008 Ford Explorer Check RSC now ABs Traction control and wrench on Stock 2006 -2010 Explorers 4
A Solved 2006 Ford Explorer. Won’t crank. Stock 2006 -2010 Explorers 14
E 2006 Ford Explorer Eddie Bauer Stock 2006 -2010 Explorers 2
A 2006 Ford Explorer 4.0 2wd oil pressure light comes on at idle Stock 2006 -2010 Explorers 5
A 2010 Ford Explorer Eddie Bauer V8 4x4 72K Miles Stock 2006 -2010 Explorers 2
A 2010 Ford Explorer 4x4 worth buying Stock 2006 -2010 Explorers 14
S Air 2006 Ford Explorer xlt Stock 2006 -2010 Explorers 2
S 2006 Ford Explorer xlt tire sensor warning Stock 2006 -2010 Explorers 2
S 2006 Ford Explorer XLT is stuck in park. Stock 2006 -2010 Explorers 7
A 2007 Ford Explorer Passenger Side CV axle Will Not Slide in Stock 2006 -2010 Explorers 31
T 2006 Ford Explorer XLT w/5R55S Automatic Transmission Slipping In Reverse Stock 2006 -2010 Explorers 8
J 2006 Ford Explorer Stock 2006 -2010 Explorers 4
A 2006 Ford Explorer 4.0 2wd V6 7 codes Stock 2006 -2010 Explorers 0
A 2006 Ford Explorer Stock 2006 -2010 Explorers 0
F New to me 2006 Ford Explorer Eddie Bauer 4.0 quick maintenance questions Stock 2006 -2010 Explorers 6
B 2008 Ford Explorer XLT Won't Crank Stock 2006 -2010 Explorers 14
H P0455 & Ford Extended Warranty Stock 2006 -2010 Explorers 0
E 2007 Ford Explorer Intermittent Stalling Issue Stock 2006 -2010 Explorers 3
B 2007 Ford Explorer Brake Pad trouble Stock 2006 -2010 Explorers 2
N 2007 Ford Explorer XLT Header Panel Replacement Stock 2006 -2010 Explorers 0
L 2006 ford explorer -evaporator core replacement? Stock 2006 -2010 Explorers 4
C 2010 Ford Explorer Sync upgrade from 3.01 to 4.6 -- Worth it? Stock 2006 -2010 Explorers 6
M Ford Explorer 2006 (eddie bauer) Door Password Stock 2006 -2010 Explorers 8
D 2008 Ford Explorer Wrench Symbol Stock 2006 -2010 Explorers 5
D Brake pedal mushy & not safe, Ford says it's ok and no tsb on it-? Stock 2006 -2010 Explorers 8
Q Ford Explorer rattles Stock 2006 -2010 Explorers 10
C Ford Sync 2009 EB in Spanish, need to change to English Stock 2006 -2010 Explorers 9
D Throttle body - new Ford or aftermarket or reman? Stock 2006 -2010 Explorers 0
X 2008 Ford Explorer xlt Stock 2006 -2010 Explorers 4
N 2010 Ford Expedition no dash lights and no start Stock 2006 -2010 Explorers 8
Similar threads
