JerichoFan
- September 5, 2012
- Archdale, NC
- Ford Aerostar(x8) 91-97
I have a 1997 Ford Aerostar with the 3.0L Vulcan engine, 86,000 miles. My check engine light is on, and it has the following error codes:
P0340 - CMP sensor circuit fault
P0340-C CMP sensor circuit malfunction
I have an obd 2 cable, and I use obd 2 software called FORScan, so I can reset the DTCs. I can also see the status of the camshaft position sensor. When I start the engine, FORScan says the status of the camshaft position sensor is OK. After a minute or two, it goes to FAULT, P0340 and P0340-c come up, and the check engine light comes on. I have been trying to fix this for a while now. I have done research online and tried a whole bunch of things.
This is what I have tried:
- Replaced camshaft synchronizer twice (Both were new).
- Replaced camshaft position sensor. I've had 5 different sensors in it. Some were put in another Aerostar I have to see if they worked and they did.
- Switched the synchronizer and sensor with another Aerostar that is working. This Aerostar still has the check engine light come on, the other Aerostar does not.
- I have taken out the #1 spark plug, found top dead center, and checked to make sure the synchronizer is in the correct position.
- Put the timing gear and synchronizer in exact same position as my working aerostar.
- I checked the wiring to the sensor. Looked for damaged wires, and checked for continuity from the camshaft position sensor to the PCM. All checked out okay.
- Switched the PCM with another Aerostar. PCM checked out okay.
- Changed the crankshaft position sensor.
- Wrapped the camshaft position sensor and the alternator in aluminum foil. This was due to someone saying the alternator may interfere with the sensor.
