I have a pair of factory height heavy duty Shackle hanger. These are made of quarter inch steel and bolt to the factory holes in the frame. Comes with 8 Grade 8 bolts washers and Locknuts. $90 Shipped flat rate is the USA.
20160223_154056 by Matthew Dresselhaus, on Flickr
20160223_152104 by Matthew Dresselhaus, on Flickr
I also have a rear shackle hanger that mounts the shackle two inches lower. Ran by itself it will give approximately 1" of lift (may have to adjust pinion angle). This is made out of Quarter inch Steel. Bolts to the factory frame holes and includes hardware. $110 Shipped flat rate in the USA.
20160223_154139 by Matthew Dresselhaus, on Flickr
20160223_153942 by Matthew Dresselhaus, on Flickr
I have a front spring hanger made from quarter inch steel that has the bolting hole two inches below the factory location. This will give approximately 1" of lift when ran by itself(might have adjust pinion angle). Bolts to the factory frame holes with 1/2" grade 8 bolts washers and lock nuts. $125 Shipped flat rate in the USA. Combine the dropped front and rear hangers for 2" lift in the rear. Buy both for $210 Shipped in the USA.
20160223_151430 by Matthew Dresselhaus, on Flickr
20160223_152437 by Matthew Dresselhaus, on Flickr
20160223_152457 by Matthew Dresselhaus, on Flickr
