Ford Recalling 1.2 million Trucks and Vans
96ExplorerSport
Pittsburgh PA
96 X Sport 4.0L OHV, 4WD
What is IVD? How can I tell if my 96 Sport has it? I checked my switch and it's hot only when key is in ON position, not 24/7. I still plan to replace it though with a new one.
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
AFAIK, the 98s were the only ones with the switch hot 24/7. If the switch isn't hot with the key off, there's no need for a replacement switch unless it's leaking.
-Joe
gijoecam
Village Idiot
Trenton, MI
Update: Found this on teh daily broadcast messages:
6004 - ANNOUNCING SAFETY RECALL 05S28-S8
CERTAIN 1994-1996 MODEL YEAR BRONCO, 1994-2002 F-150 THROUGH F-550, 1997-2002 EXPEDITION, 1998-2002 NAVIGATOR, 2002 BLACKWOOD,1994-1996 E-150/250/350, 1996-2002 E-450, 2000-2002 EXCURSION, AND 1998 EXPLORER AND MOUNTAINEER VEHICLES EQUIPPED WITH SPEED CONTROL - SPEED CONTROL SYSTEM MODIFICATION. THE DEALER BULLETIN HAS BEEN POSTED TO FMCDEALER.COM
So, a quick trip to FMCDealer, and I found this:
Frank M. Ligon
Director
Service Engineering Operations
Ford Customer Service Division
Ford Motor Company
P.O. Box 1904
Dearborn, Michigan 48121
August 3, 2006
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Safety Recall 05S28 - Supplement #8
Certain 1994-1996 Model Year Bronco, 1994-2002 F-150 through F-550, 1997-2002 Expedition, 1998-2002 Navigator, 2002 Blackwood,1994-1996 E-150/250/350, 1996-2002 E-450, 2000-2002 Excursion, and 1998 Explorer and Mountaineer vehicles equipped with Speed Control
Speed Control System Modification
REASON FOR SUPPLEMENT #8
The purpose of this supplement is to:
Announce that the affected vehicle population for this recall is being expanded to include additional vehicle lines and model years (under "Affected Vehicles", see "GROUP B: Supplement #8" below).
Revise the service procedure for vehicles exhibiting a leaking Speed Control Deactivation Switch (Labor Operation 05S28E).
Reemphasize the importance of properly drying and greasing the vehicle wiring harness connectors as directed in the Technical Instructions.
Provide claiming instructions for electrical grease.
AFFECTED VEHICLES
GROUP A: Original and Supplement #5 - Vehicle Population
Year
Model
1994-1996
Bronco
1994-2002
F-150
1994-1999
F-250 (Under 8500 GVW
1997-2002
Expedition
1998-2002
Navigator
2002
Blackwood
GROUP B: Supplement #8 - Added Vehicle Population
Year
Model
1994 – 1996
E-150, E-250, and E-350
1996 – 2002
E-450
1994 – 2002
F-250 through F-550 Super Duty Trucks (Over 8500 GVW)
1998
Explorer/Mountaineer
2000 – 2002
Excursion
* Vehicles equipped with diesel engines are not affected.
REASON FOR THIS SAFETY RECALL
The underhood Speed Control Deactivation Switch (SCDS) may overheat, smoke, or burn, which could result in an underhood fire. The potential for a fire exists regardless of whether speed control is being used or the engine is running.
SERVICE ACTION
At no charge to the vehicle owner, dealers are to:
Disconnect Speed Control Deactivation Switch wiring harness connector and check for presence of brake fluid contamination in the electrical connector on all affected vehicles.
If the Speed Control Deactivation Switch electrical connector is not contaminated with brake fluid: Install the Fused Jumper Harness.
If the Speed Control Deactivation Switch electrical connector is contaminated with brake fluid: Using compressed shop air, blow dry the Speed Control Servo electrical connector and the speed control switch harness connector. Apply electrical grease to the servo connector and to the speed control switch adapter jumper harness male pin connector. Install the Brake Repair Kit (Speed Control Deactivation Switch Kit).
They also have a copy of the owner letter, reimbursement procedures, and a background summary, but they're PDF files and I can't copy the text easily.
So, it looks like the official word is that it'll only be for the 98 Explorers and Mountineers with cruise control.
-Joe
G
gensic11
what about the people with the "pre-98" model.. that's technically a 97 but has features of a 98. i have the late 97 model and i wonder if they switched the cruise on my model as well..
96ExplorerSport
Pittsburgh PA
I know that 96 has the same switch, so it still can leak. The only difference is that it is not hot 24/7, so I'll be there when the fire starts :) . If you have a voltmeter you can check the voltage across the sensor when engine is OFF. I plan to replace mine anyway, for a peace of mind.
gijoecam
Village Idiot
Trenton, MI
The 97 lists it as being hot all the time as well. I can't say why it's not been included in the recall. It may be a matter of 'It's not included YET' or it may be a matter of 'they're not seeing the problems in the 96 for XXXXXX reason.' I have no way of knowing why they wouldn't include them. My best guess is that the fuse that's in-line is only a 7.5A on the 96, so maybe it was determined that the 7.5A fuse will blow before it becomes a fire hazard. I dunno... That's strictly supposition on my part.
If you have questions, you can contact the dealer and they can reference the VIN number to see if yours may be affected.
As I've said all along, it's not going to hurt anything to replace it.
-Joe
dogfriend
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
My 97 schematic shows that it is only Hot In Run, not Hot At All Times.
My switch is leaking like a sieve and I lost cruise control a couple of weeks ago. Guess I'll be getting a new switch.
The manual says you should bleed the brakes after installing a new switch.
P.S. I park out in the driveway away from the house. Maybe I should reinstate my comprehensive insurance? :D
A while back I added a 1/2 amp fuse to the hot wire just above the connector for the switch. I'll probably go get the Ford part just to see how it's put together.
I like the fuse even with the newer switch, since you still have a similar part that could potentially fail. the real problem is that the circuit is always hot.
Runnin'OnEmpty
Southeast USA
2000 Sport
I think a fuse is a good idea even on the models that the circuit is 'hot while running'. After all, if the fire starts while driving down the highway, there's still the possibility of vehicle loss.
Whether running or parked, there's still a danger, in my humble opinion...... :rolleyes:
dogfriend
Human-Animal Hybrid
Carmichael, CA
'97 Sport 4x4
Yeah, but if you are moving down the road and you see smoke coming from under the hood, you can pop the hood open to try and blow it out. :p
davesexplorer
Central PA
2001 F350 7.3
Hmmm my 99 has the red switch...
wpurple
CT
97 Explorer 12 Escape
My 98 Mountaineer is hot all the time....
gijoecam
Village Idiot
Trenton, MI
As stated in the recall above, your 98 Explorer/Mountaineer will be included in the expanded recall.
C Ford is now a surveillance company and autos are just the means for that end Exploring everything under the sun!! 2
Rick Shelby American on Netflix & Ford vs Ferrari Exploring everything under the sun!! 0
S My 2017 F150 Lawn Ornament... Thanks Ford! Exploring everything under the sun!! 18
Rick Video - Riding offroad in Ford Explorer with over 400,000 miles Exploring everything under the sun!! 1
swshawaii Born Tough: Inside the Ford Factory | HISTORY CHANNEL Exploring everything under the sun!! 0
ProjectAviator Question for a Ford/Lincoln Tech Exploring everything under the sun!! 3
A Ford Explorer 2003 Eddie Bauer Edition Exploring everything under the sun!! 0
Tbars4 91-94 Lego Ford Explorer Exploring everything under the sun!! 2
Maniak Ford knew how to flex an off-road rig Exploring everything under the sun!! 2
T Ford's Thirty Under 30 Exploring everything under the sun!! 0
Tbars4 Ford Explorers at SEMA 2015 Exploring everything under the sun!! 0
R I love ford but new CEO is crazy!!! Exploring everything under the sun!! 6
D 2016 Ford GT, When you see it.. Exploring everything under the sun!! 2
L Ford NAIS Exploring everything under the sun!! 4
T Capital Ford Cruise In Pictures & Video 5-3-2014 Exploring everything under the sun!! 2
BKennedy Why I don't think I will purchase another Ford Exploring everything under the sun!! 4
reapereviltwin Ford lovers FB page Exploring everything under the sun!! 0
C So Ford is tracking customers hunh? Exploring everything under the sun!! 2
L 2015 Ford F150 Exploring everything under the sun!! 3
Anime Ford Ranger plunges off overpass onto a frozen lake...and the driver walks away Exploring everything under the sun!! 6
NICE59FORDF100 1992 Ford New Model Overview and Technical Service Features VHS Video Exploring everything under the sun!! 1
NICE59FORDF100 1995 Ford Explorer Owner's Guide Video Exploring everything under the sun!! 2
NICE59FORDF100 1993 Ford Explorer and Bronco Sales Highlights Video Exploring everything under the sun!! 0
swshawaii Henry Ford & Kingsford Charcoal Exploring everything under the sun!! 0
Tbars4 ..Another Ford sells for $4.2 Million Exploring everything under the sun!! 1
2TimingTom Ford: Rebuilding an American Icon Exploring everything under the sun!! 0
Y vote ford explorer 2012!!! Exploring everything under the sun!! 4
SoBeLover Drunk driver crashes Ford Explorer through the front of a convenience store Exploring everything under the sun!! 3
reapereviltwin Trip to the Henry Ford Museum. Exploring everything under the sun!! 13
S had job interview on thursday at ford & lincoln dealership Exploring everything under the sun!! 67
1 advise...2002 ford explorer limited Exploring everything under the sun!! 0
Dan Whitaker Ford sweeps GP at Daytona Rolex 24 hour. Exploring everything under the sun!! 3
H Perhaps The Best Ford Commercial Ever Exploring everything under the sun!! 8
FIND .:: Ford Explorer Picture Challenge Game ::. Exploring everything under the sun!! 57
Dan Whitaker Ford VS Chevy Exploring everything under the sun!! 14
L FORD: Built without your TAX dollars Exploring everything under the sun!! 7
X Jurassic Park Ford Explorer / Exploder Exploring everything under the sun!! 12
Flounder Ford F150 Defeats Ferrari Exploring everything under the sun!! 19
K 91 Ford Explorer Commercial Exploring everything under the sun!! 3
F Need a compressor? Got a Ford V8? Exploring everything under the sun!! 8
S I know it's not a Ford... Exploring everything under the sun!! 12
W Ford trucks rock! Exploring everything under the sun!! 2
lynchy wa Jesus drives a Ford Exploring everything under the sun!! 8
B Ford F150 Forum? Exploring everything under the sun!! 3
bcbid Ford Explorer....Facebook Exploring everything under the sun!! 4
Rick My first Ford - '74 F250 Exploring everything under the sun!! 7
Brandon96 Ford's Modular 4.6L, School me? Exploring everything under the sun!! 12
Flounder Ford Sales Persons or Auction Attendees? Exploring everything under the sun!! 2
J Ford settles suit in Mets prospect death Exploring everything under the sun!! 3
Stic-o Ford Explorer 20th Anniversary! Exploring everything under the sun!! 4
Similar threads
