  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Ford TracLoc Clutch Set, Short Ears?
BobWiersema
Chicago Burbs, Illinois
98 xlt 4.0L SOHC 4x4
Hi all,
I'm looking at Rock auto for a differential clutch set. I see two choices, one of them says "short ears".
How do I know which one to order? Without taking it apart first.
98 Explorer, Axel code D4
Thanks in advance,
Bob
96eb96
Albany, NY
96 EB V6 OHV 4WD
BobWiersema
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
I also would 2nd a Ford racing rebuild. They also make a standard replacement option and they are Ford parts. I'd go ford parts way before multi vehicle fit aftermarket stuff.
96eb96
Albany, NY
96 EB V6 OHV 4WD
That's zero help. I didn't ask what Mustang performance parts would you buy?
The internals are 100% interchangeable to a mustang. Why not get the best. I actually installed the whole trac lok carrier from the site. Like boomin said the factory ford one is available on the site too. That is what you would get from the dealer. This is a part under very high stress, you want something very heavy duty!
Ford Performance Mustang Traction - LOK Rebuild Kit - 8.8 in. M-4700-B (86-04 V8) - Free Shipping
BobWiersema
So don't use multi vehicle parts, use mustang parts. Great idea, do I use the Cobra, GT or V6 kit? Mustang uses 1 less clutch on each side so should I order two kits?
Also, Ford does not make these parts. They are made by USA Standard Gear. Same parts are sold by Rock Auto for half the price.
If you are unfamiliar with rebuilding these differentials, please don't respond. "Buy Mustang parts" is not helpful in anyway.
This is what I've learned so far.
1. The clutch plate next to the gear looks like it is worn out. Normal condition.
2. The clutch pack Ears are square from 1983 (and before) through at least 1989.
3. The clutch pack Ears are rounded from before 1995 to at least 2001.
4. The Differential Case has square slots from 1983 (and before) through at least 1995.
5. The 2001 Differential Case has drilled holes in the end for Short Rounded Ears clutch packs and will not take square Ear clutch packs or Rounded Ears clutch packs from 1995.
So I think they are the round ones.
If you have rebuilt one of these, let me know.
shucker1
Metairie, Louisiana
98 XLT 5.0
Factory for 98 8.8 Rear End does have Round Ears.
M-4700-B is the factory replacement kit.
I used M-4700-C Kit Which is Carbon Fiber Clutch Material.
You must use the friction modifier or your rear end will grab really hard in turns.
Friction Modifier actually lets the clutches slide past each other in turns.
Once rebuilt it would be best course of action to take your truck to an empty parking lot and drive a few figure 8 turns to work the clutches in.
New one will be few noisy for the first few miles.
From reading your post I would suggest the M-4700-B kit for your application.
During install PLEASE wear safety glasses. The "S Spring" is under a lot of load and may pop out and whack you in the face.
While the truck is down it may not be a bad idea to change out you rear axle shaft seals.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
It's an 8.8 diff, same as Mustang GT. The V8 mustang's, Explorer and F150 use the same 8.8.
I'm just as sour with rock auto from a bad experience as you are with your replies. How are you so sure the USA gear clutches are the exact same as the Ford. Also I've never seen 4 clutch packs on either side of a factory diff, it's always 3 with 2 plates back to back in one spot. Some people add the 4th between those for extra preload.
I've pulled apart at least 50 8.8 rear diffs, please don't be a dick to people trying to help. Oh and yes you need the rounded ears since your axle is 95+ (94 and before were square)
96eb96
Albany, NY
96 EB V6 OHV 4WD
I looked on Rockauto and I don't see the savings he is talking about! I paid less for an ENTIRE carrier what the Carbon Fiber ones cost. I would hope they are the Ford ones at that price, they are probably good quality as well.
You are also putting $50 of synthetic fluid in...Any savings would be lost there unless you pump it out. I drive on dirt roads up hills and that CF setup is excellent.
L O/D off light flashing in 99 Ford Explorer. Stock 1995 - 2001 Explorers 6
I Anybody currently living in Ford's Electroville? Stock 1995 - 2001 Explorers 1
A 1997 Ford Explorer 4x4 Rear Differential Stock 1995 - 2001 Explorers 2
W Problem with ABS on 1998 Ford explorer XLT Stock 1995 - 2001 Explorers 2
L 1996 Ford Explorer XLT ABS Module Failure Stock 1995 - 2001 Explorers 9
S 99 Ford Explorer 4.0 SOHC Help Stock 1995 - 2001 Explorers 19
T 1996 Ford Explorer front diff Stock 1995 - 2001 Explorers 4
D 98 ford explorer engine missing Stock 1995 - 2001 Explorers 10
T 1996 Ford Ranger 2.3l won’t start After you shut it off Stock 1995 - 2001 Explorers 3
R 97 Ford explorer awd Stock 1995 - 2001 Explorers 1
D I have a 2003 ford explorer sport 2 door. Stock 1995 - 2001 Explorers 1
F 1996 Ford Explorer V8 AWD blown fuse or circuit Stock 1995 - 2001 Explorers 2
E 1997 Ford exploder XLT Alarm Will Randomly Go Off, Thoughts? Stock 1995 - 2001 Explorers 8
B Hi I am blossom45 and the first time for me owner of a 96 ford explorer l Stock 1995 - 2001 Explorers 25
F 95 Ford Explorer code 998, 113, along with ABS light Stock 1995 - 2001 Explorers 2
K Convert My 1998 4.0 AWD manual transmission Ford Explorer to 2 wheel rear drive Stock 1995 - 2001 Explorers 1
J 1997 Ford Explorer XLT--Need Part F77Z3B676EA Stock 1995 - 2001 Explorers 18
A Abs Pump Test - 1997 Ford Explorer 4.0 OHV Stock 1995 - 2001 Explorers 1
E (1997 Ford Explorer bolt hole spacing on flange) Stock 1995 - 2001 Explorers 0
L Keyless entry 2000 Ford explorer XLS Stock 1995 - 2001 Explorers 2
D Possible PCM damage, PCM and electrical function diag. 2000 Ford Explorer Limited Stock 1995 - 2001 Explorers 1
C G-WAGON style DRL on FORD EXPLORER Stock 1995 - 2001 Explorers 0
J 1999 Ford Stock 1995 - 2001 Explorers 5
C I have a 1999 ford explorer that has a loud banging when drive , I was told it was the transfer case . How can I tell ? Stock 1995 - 2001 Explorers 5
A Everything is stock. 96 Ford Explorer radio has no audio. Display works, stations work, ect. Just no volume. Stock 1995 - 2001 Explorers 8
I Buying a 99 explorer 4x4 first ford what should I look for any common problems? Stock 1995 - 2001 Explorers 24
C FORD EXPLORER REVIEW - probably the most detailed analysis of popular SUV Stock 1995 - 2001 Explorers 20
T 2000 Ford explorer transmission problems Stock 1995 - 2001 Explorers 2
E 2001 ford explorer sport Stock 1995 - 2001 Explorers 2
L 98 Ford explorer. Cranks but no start Stock 1995 - 2001 Explorers 2
F What items need to be done before long trip - 1998 Ford Explorer XLT w/ 215,000 miles Stock 1995 - 2001 Explorers 5
M Replacing cat. converter on 1995 Ford Explorer 146,000 miles , second owner Stock 1995 - 2001 Explorers 0
T P0113 Ford OEM Enhanced KOEO Stock 1995 - 2001 Explorers 1
Z Ford Explorer Issues Stock 1995 - 2001 Explorers 28
poker4me007 How to install a oil pressure gauge in a 97 Ford Explorer (video) Stock 1995 - 2001 Explorers 2
S 1997 Ford Explorer rear door handle replacement Stock 1995 - 2001 Explorers 1
C 1998 Ford Explorer 4L OHV engine freeze plug trouble Stock 1995 - 2001 Explorers 13
C Ford Parts Manual / Diagram Stock 1995 - 2001 Explorers 6
D 00 Ford explorer Stuck in 4WD Stock 1995 - 2001 Explorers 12
K 1999 Ford Explorer shifts out of gear going uphill... Stock 1995 - 2001 Explorers 16
M Code P1400. 2001 4.0 Ford Explorer Stock 1995 - 2001 Explorers 3
R Ford Trailer Light Harness Part Number Stock 1995 - 2001 Explorers 3
D 96 Ford Explorer: Belt tensioner gone bad- is it worth it? Stock 1995 - 2001 Explorers 19
GrayGhost96 96 ford explorer optional "sport seat" Stock 1995 - 2001 Explorers 5
T 1998 Ford Explorer timing chain Stock 1995 - 2001 Explorers 2
D New "to me" 1996 Ford Explorer XLT 4.0l 4WD Stock 1995 - 2001 Explorers 9
P Preventative Maintenance 2000 Ford Explorer Stock 1995 - 2001 Explorers 37
J New member 95 Ford Explorer XLT 4x4 4.0 window wiring Stock 1995 - 2001 Explorers 5
9 96 Ford Explorer No heat, Not Blend Door Stock 1995 - 2001 Explorers 4
E 1997 Explorer - what year Ford Linc Merc Radios have exact same connectors Stock 1995 - 2001 Explorers 3
Similar threads
