FORScan code to enable reverse camera delay? | Ford Explorer Forums - Serious Explorations
blob19
Midwest
2016 Interceptor Utility
Does anyone know how to enable the reverse camera delay menu option?
Is it an OEM camera? On the vehicles I've had there is a setting you can chose in the Camera options. I have had all mine set on 'Delay'.
Yes, exactly. I do not have the option.
Edit:
I should add- I do recall seeing the option at one point but I didn't understand what it did and never used it. Recently I found out what it did, so I wanted to enable it. I suspect that when I edited some other things in FORScan I may have inadvertently disabled the menu option.
I was hoping someone knows the exact memory address that controls whether this option is displayed in the menu or not.
