Forscan help with ABS IDV Utilization
mhhtcc263
Norfolk,VA
2007 Explorer Eddie B
2007 EB 4.0L. ASB fault code c1991. Alarm sounds every 5 minutes and Service RSC NOW message. Unable to clear code using OBDLink MX. I stumble upon Forscan and from a previous post it was recommended that I use IDV utilization. How is that done? Do I need a parameter data from a spreadsheet? If I need that spreadsheet, where can I get it? I have the forscan program and the OBDLink MX+ module.
M forscan pats...just a rant if i might have missed something Stock 2006 -2010 Explorers 2
S ELM327- FORScan lite connection issue solved Stock 2006 -2010 Explorers 1
M Forscan Users Stock 2006 -2010 Explorers 12
M FORScan tool Stock 2006 -2010 Explorers 5
S 07 Eddie Bauer 4.0l SOHC Bank 1 Sensor 1 Wiring Help Needed Stock 2006 -2010 Explorers 3
W Hi, need help with balance shaft Stock 2006 -2010 Explorers 3
K Ford explorer wiring help Stock 2006 -2010 Explorers 0
T Help abs and rsc lights on Stock 2006 -2010 Explorers 0
A Brake Caliper help needed Stock 2006 -2010 Explorers 0
J Help locating hissing air sound and identifying vacuum hose Stock 2006 -2010 Explorers 1
W 2007 mountaineer 4.6L p050B code help Stock 2006 -2010 Explorers 1
A PLEASE HELP Stock 2006 -2010 Explorers 0
P Help!!! Stock 2006 -2010 Explorers 5
F Transmission help!! 5r55s shift solenoid? Stock 2006 -2010 Explorers 2
F Transmission help!! Stock 2006 -2010 Explorers 0
M P0305 issue. Need help Stock 2006 -2010 Explorers 4
M Please help me find the part number Stock 2006 -2010 Explorers 2
C Rear trailing arms help! Stock 2006 -2010 Explorers 14
T Is there help to Replace Fuel Injector 4.6L Stock 2006 -2010 Explorers 3
D Help/tips removing rear axle shafts. Stock 2006 -2010 Explorers 18
J Installing new bumper and fenders question!!!! Please help Stock 2006 -2010 Explorers 1
A I'm new here and i need help please . My 2010 Explorer won't start Stock 2006 -2010 Explorers 7
M Help with 5r55s! Stock 2006 -2010 Explorers 3
D Differential gurus, help? Squeaking and more.. Stock 2006 -2010 Explorers 5
W Won a 2006 Explorer at an auction... Need some help! Stock 2006 -2010 Explorers 4
2 4.0 sohc fuel injector questions / help for those with brakes locking Stock 2006 -2010 Explorers 4
G 5r55s problem help Stock 2006 -2010 Explorers 2
R Need help with Sync Stock 2006 -2010 Explorers 4
F Help with ABS Control Module Nightmare!! Stock 2006 -2010 Explorers 8
S Smart Junction Box Problem? HELP! Stock 2006 -2010 Explorers 0
S Urgent Help B229B Car Wont Start Stock 2006 -2010 Explorers 2
F ABS B1342 Code Help Stock 2006 -2010 Explorers 8
D 2007 Ford Exploder Help!!! Stock 2006 -2010 Explorers 3
D 2007 Esplora tire size help. Stock 2006 -2010 Explorers 2
Mitchs07explorer Help P0442 evap small leak Stock 2006 -2010 Explorers 6
P Need door latch assembly help... Stock 2006 -2010 Explorers 0
F A/C electronics diagnostic, help Stock 2006 -2010 Explorers 13
J 2006 PCM pinout? - hows it going new member plse help Stock 2006 -2010 Explorers 0
I Help! new plugs etc.. Stock 2006 -2010 Explorers 2
W Need Transmission Help Stock 2006 -2010 Explorers 32
A Caliper Speed Bleeders, Help. Stock 2006 -2010 Explorers 8
R Need Troubleshooting Help - Transmission Going Erratic Stock 2006 -2010 Explorers 15
K Help needed for '10 V6. Stock 2006 -2010 Explorers 5
S Help! 2006 Explorer starts but pedal is dead Stock 2006 -2010 Explorers 3
O 4.0 Good Pressure but AC Clutch Cycles Sporadically. No cold air. HELP! Stock 2006 -2010 Explorers 5
J 2010 Liftgate/Glass Ajar Message Help Stock 2006 -2010 Explorers 1
J Another 5r55s transmission tragedy - please help Stock 2006 -2010 Explorers 34
D 09 4.6 Explorer trailer airing help! Stock 2006 -2010 Explorers 5
C 08 Ford Explorer 5r55s transmission part? Need Help. Stock 2006 -2010 Explorers 6
D Diagnosing Noise Help Stock 2006 -2010 Explorers 5
Similar threads
