1QUICK23
- November 29, 2020
- salem
- 1988 Tbird Turbo Coupe
Looking at buying an 88 turbo coupe thunderbird automatic. I know this is an explorer/ranger forum but since they share the same model trans up to 94 and there seems to be alot of good trans tech advice on here i joined to get some help.
I know the stock 4cyl A4LD in the 87-88 TCs is a big weak point. Im looking to buy a 94 4.0 trans with 89k and doing all the upgrades i can short of rebuilding it, that will come later. For now i just want it reliable for 14-18lbs of boost.
Here is my list so far..
• Hughes custom torque converter
• 1994 4.0 A4LD 89K
• Cryo input
• Superior kit
• Trans cooler
• 13qt Amalie Dex/Merc
• LubeLocker A4LD pan gasket
• Motorcraft filter mt-58
• Timken input seal
• Timken output seal
• Upper and lower seperator plate gaskets
Im unsure which servos to run. Otherwise am i missing anything or should i go with different parts? Does baumann still calibrate a4ld valve bodies?
• 1994 4.0 A4LD 89K
• Cryo input
• Superior kit
• Trans cooler
• Timken input seal
