TedStryker
- May 20, 2015
- Rancho Cordova, CA
- 1993 Explorer 4x4 Limited
This is probaby nothing and you'll likely laugh at me for even posting this. I changed my oil yesterday and found this in my oil drain pan. It looks like a piece of a drill bit that might have randomly fallen into the pan and initially I dismissed it as such. Then it started to bother me a bit, so I took a closer look. All of my drill bits are accounted for, and I don't remember ever breaking one like this. (Maybe in half once, yes. But not on both ends.) And on closer inspection, this piece seems to have some wear on the outter edges that my drill bits do not.
Is there anything like this that might break off inside of a 4.0L V6 (1993)? Engine seems to run ok. Idles a little rough sometimes, but overall runs pretty good. Has 210K miles.
I've never taken an engine apart so this question probably seems extremely amateur. Again, if this is just a stray piece of metal that somehow fell into my drain pan, you're welcome for the giggle. Thanks in advance for any thoughtful replys!
