found this nice bumper
slowtruggy
lumberton tx
1994 explorer
found this nice bumper in a junk yard in beaumont tx I got it off a 92 explorer can't wait to put it on my 94
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
Looks like scrap steel to me, better let me take it off your hands.
Seriously though, that is sweet. Wish I could find something like that.
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
That's the old Smitty built Toyota pick-up front bumper.
Plenty of those to be found at the foreign truck bone yards.
Easy to adapt to the Ex. Just need to fab a bracket.
One of these days when I totally chew the limited bumper to shreds that's gonna be the replacement. I have the rear too from my old 80' yota.
No their not for sale, sorry.. .. ..
orange 94
Los Angeles
1994 Ford explorer xlt
slowtruggy
lumberton tx
1994 explorer
that's what it is just ordered new end caps for the tubs I'm going to take it and get it powder coated
FR-425
Phoenix, AZ.
I built a hinge for the end caps, makes a good tow strap or chain storage
slowtruggy
lumberton tx
1994 explorer
that's a good idea
EMBRACETHEHATE89
93 Limited 4x4 Explorer
sweet find!
T Found in oil drain pan. What is it? Stock 1991 - 1994 Explorers 8
D found my ecm Stock 1991 - 1994 Explorers 0
D found a trailer wiring harness. Stock 1991 - 1994 Explorers 5
J Mystery Connector - found searching for bouncing voltage issue. Stock 1991 - 1994 Explorers 4
M Solved The PCM fuse keeps blowing out. The bad wiring was found under the throttle body. Stock 1991 - 1994 Explorers 21
E 1994 Ranger 4x4 front end needed. No parts to be found ?? Stock 1991 - 1994 Explorers 5
S Found a leak! Stock 1991 - 1994 Explorers 9
P Metal spring found in driveway as I backed out.. Stock 1991 - 1994 Explorers 9
M Found disconnected vacuum tube, where might it go? Stock 1991 - 1994 Explorers 4
C replacing heads, found some worn out parts Stock 1991 - 1994 Explorers 2
F FINALLY found the culprit!!93 explorer fuel wiring harness Stock 1991 - 1994 Explorers 15
1 Interesting red plug - FOUND Stock 1991 - 1994 Explorers 9
I Spring found, from the Explorer? Stock 1991 - 1994 Explorers 7
F Brakes locked up -- and fix found Stock 1991 - 1994 Explorers 8
M Think I found the rattle. Stock 1991 - 1994 Explorers 7
G Brown o-ring found on driveway after working on engine???? Stock 1991 - 1994 Explorers 9
M Ignition System - Black Wire Found Stock 1991 - 1994 Explorers 1
S I found this Stock 1991 - 1994 Explorers 4
T Has anyone found stock 4.10's? Stock 1991 - 1994 Explorers 8
davidhicks16 I found a good deal on lockouts Stock 1991 - 1994 Explorers 4
safn1949 Found a first gen EX Stock 1991 - 1994 Explorers 0
M Coolant loss, found leak. Stock 1991 - 1994 Explorers 2
BWTGUY Just Found A Good Deal Stock 1991 - 1994 Explorers 0
P Where are the trim exterior paint codes to be found on 94 Limited?? Stock 1991 - 1994 Explorers 1
A Found something in my transmission oil pan. what is it? Stock 1991 - 1994 Explorers 3
H Bad FPR and how I found it and the replacement. Stock 1991 - 1994 Explorers 0
A how to replace driver side wheel bearing on 94 ex (solution found) Stock 1991 - 1994 Explorers 3
S found this about auto locking hubs Stock 1991 - 1994 Explorers 4
bcbid Found my elusive battery drain!!!!! Stock 1991 - 1994 Explorers 1
E Found a used Motor, but........?? Stock 1991 - 1994 Explorers 10
K 92 4x4 explorer (have searched threads and found nothing) Stock 1991 - 1994 Explorers 21
Four0Sport what i found when i took my front hub off.. Stock 1991 - 1994 Explorers 15
K I've Found The Answer! Stock 1991 - 1994 Explorers 0
M Uh oh....found the problem Stock 1991 - 1994 Explorers 9
D Found a 93 Ex 2WD Buy It? Stock 1991 - 1994 Explorers 6
Y Found a dead mouse... Stock 1991 - 1994 Explorers 10
M FOUND: Brand New Explorer Bikini Hood Cover (OEM FORD) Stock 1991 - 1994 Explorers 17
J Found an answer to most engine noise probs!!! Stock 1991 - 1994 Explorers 0
B Found Electrical Problem need Help Stock 1991 - 1994 Explorers 4
S Found Broken Vac. Line Assembly uknown Stock 1991 - 1994 Explorers 7
ryf weird stumbling, found fix, new issue Stock 1991 - 1994 Explorers 3
D nice scores from the junk yard today Stock 1991 - 1994 Explorers 3
M Nice annoying CLUNK Stock 1991 - 1994 Explorers 1
L Nice to meet you :D Stock 1991 - 1994 Explorers 0
J First Gen Explorers ride pretty nice. Stock 1991 - 1994 Explorers 30
R Is this bumper OEM? Stock 1991 - 1994 Explorers 4
S 1992 Explorer XLT - Rear bumper replacement? Stock 1991 - 1994 Explorers 6
S My bumper put on finally Stock 1991 - 1994 Explorers 1
P In need of a 1st gen front bumper!! Stock 1991 - 1994 Explorers 8
N pusher bumper replacement Stock 1991 - 1994 Explorers 4
Similar threads
