Hi all,
For all those body work and paint geniuses, I had some trouble with the passenger door this past weekend for some odd reason. Used an Epoxy Primer Sealer over the old paint which was mixed with catalyst and about 10% of reducer to thin it out. Laid the primer, even coats although I may have not let appropriate flashing times between.
Well when I laid the base coat, about 10 minutes later after cleaning the gun I started to get some spider cracks showing through the base coat (color). Slowly but surely more and more showed up, mostly in the jams and on edges.
So, anyone ever experienced this problem before? Resolution? I'm thinking either my base or primer coats might have been too thick without sufficient flashing? It was about 90 deg outside with a high humidity. HELP?
