koda2000
- September 2, 2011
- x
this is long and there isn't really a question associated with it, so you don't need to read it unless you like listening to someone else's tale of how i spent my Saturday.
well, i finally got my daughter's 2000 Mountaineer 5.0L AWD delivered by AAA this morning. turns out the AAA member MUST be present when the car is picked up and she was on vacation in Myrtle Beach all week (how nice for her...) she had run over something in the road and blew a tire. once a spare was put on she called all freaked out to say it was leaking what she thought was trans fluid. turns out it was leaking front dif fluid out both the driver and passenger side axle seals. it didn't have anything to do with the flat tire. it was pretty well pouring out the passenger side, but the driver's side had been leaking pretty good too. knowing my daughter, it's probably a good thing she blew a tire or we never would have known the front axle seals had bellied up and she would have driven the truck into the ground. stupid AWD... the seller said it was RWD, but that's another story.
so i went to work removing the wheels, brake calipers and mounting brackets, rotors and axle nuts. then i took the outer tie rod ends and ball joints loose and removed the steering knuckles. all the ball joints are a little on the rattlely side and i'd really like to change the uca's and the lower bj's while things are apart, but she only has the money for the axle seals, fluids and a new tire right now and i gotta get the truck fixed and back to her asap, so i guess i'll leave the bj's go until next spring. she doesn't plan on keeping the truck much beyond then and only drives about 30 miles round trip to work, all on secondary roads, ssssoooo...
of course the shock bolts on one side snapped off (original OE's) so now i have to remove the rusty-ass top nut so that i can get the shock off to grind off the welded-on bolts and replace them with some grade 8's. this truck spent quite a bit of time up north, so rusty bolts are the norm. i feel for you guys who live in the rust-belt. it makes everything at least twice as difficult to do. i was able to get all the other nuts and bolts off fairly easily with the use of my impact wrench and WD40. the one thing that took an inordinate amount of time was getting a too-small rusty cotter pin out of one lower bj because i couldn't grab the damn head with anything. that wasted a 1/2 hour. i'm letting the upper shock bolts soak overnight. if i can't get them off tomorrow, out comes the saws-all and on will go some cheapie front shocks.
the front axles came out w/o a problem, but the old seals needed to be beaten out. so now the parts are on order at AutoZone and will be in tomorrow morning. then i get to put everything back together again, hopefully w/out leaks. then i need to pull the rear drive shaft to change a leaky rear t-case output seal, and adjust the new parking brake shoes i installed a couple of months ago, but couldn't adjust at the time as i had a pinched nerve in my neck. then fluids and a new tire on Monday and back it goes.
if this truck survives my daughter until spring, i may take it back and keep it around as a spare vehicle. it been a pretty good truck for $2000, but no used vehicle can survive total neglect.
