Dasan458
- July 16, 2014
- North Carolina
- 2000 Ford Explorer
2000 5.0 explorer. I’ve had this thing for a year and a half now and have done a few things. Swapped to manual 4wd transfer case and replaced a bunch of worn parts.
Ever since, my front brakes have been dragging a little bit, enough to feel resistance when spinning the wheel when it’s off the ground. At first I thought it was the front diff binding but after pushing the pistons back in they spun freely. Since then I’ve replaced both calipers, brackets, hoses, brake flush, and even put spacers behind the master enough to release pressure when not pressing the pedal. Still dragging.
Only thing I haven’t changed it pads and rotors because there is still plenty left. I have used a ton on brake grease on the pins and clips and still nothing.
I know there should be some resistance but this is enough to slow the vehicle down to a stop coasting downhill. Any suggestions?
