Front Bumper - 2 Piece - upper needed
Tike
Greater Philadelphia
08 Ford Sport Trac XLT
long story. someone ran a stop sign - no witness and cracked my front bumper and now im stuck repairing it.
FO1000600
and inner fender extension ( bought one already)
so i am looking for anyone parting out an X or ST 4th gen or selling a painted Black front bumper. *dont feel like buying a primed one and having it painted if i can avoid it.
didnt see one on the for sale area of the forum.
E I damaged the front bumper...Which parts do I need? Stock 2006 -2010 Explorers 2
I 08 front bumper Stock 2006 -2010 Explorers 1
G 2010 Explorer Front Bumper Rattling Loose at Fenders Stock 2006 -2010 Explorers 5
F Front bumper removal Stock 2006 -2010 Explorers 1
D 2008 Ford Explorer Front Bumper Cover Removal? Stock 2006 -2010 Explorers 3
W 2008 Explorer XLT Front Bumper Cover Replace Stock 2006 -2010 Explorers 2
B Removal of front bumper cover? Stock 2006 -2010 Explorers 0
D 2006 Limited Explorer Front Bumper Cover Stock 2006 -2010 Explorers 1
K need info on front bumper support configuration Stock 2006 -2010 Explorers 1
J Front bumper replacement Stock 2006 -2010 Explorers 3
S Front Bumper & Running Board Paint Peeling Stock 2006 -2010 Explorers 4
G Front bumper chin (plastic thingy) question Stock 2006 -2010 Explorers 0
T bad bearing like noise in front Stock 2006 -2010 Explorers 7
M HVAC Front Air Vent Vacuum Motor Access Stock 2006 -2010 Explorers 5
V Front abs sensor replacement Stock 2006 -2010 Explorers 1
F Abs and traction control lights still on after front hub replacement Stock 2006 -2010 Explorers 2
M Front Wheel/Axle Noise Stock 2006 -2010 Explorers 5
M Hey there does anyone know if I Can put 17 inch rims and tires front a f150 in my 2007 explorer? Stock 2006 -2010 Explorers 10
H 08 mercury mountaineer front end noise Stock 2006 -2010 Explorers 5
R 2006 explorer front drive shaft cv needs replacing Stock 2006 -2010 Explorers 8
B 2006 explorer front differential Stock 2006 -2010 Explorers 10
T Front impact Sensors Stock 2006 -2010 Explorers 1
M 2010 Mountaineer noise coming from Driver Front Wheel under braking Stock 2006 -2010 Explorers 9
V Popping noise from front end? Stock 2006 -2010 Explorers 1
G Replacing front wheel bearing hub assy’s at 153K miles Stock 2006 -2010 Explorers 3
S RR,LR,Lampa and he front two lamps are giving me a warning..hazard Stock 2006 -2010 Explorers 1
T Front Wheel Hubs Stock 2006 -2010 Explorers 18
T Front hubs and ABS, wrench, and traction control lights Stock 2006 -2010 Explorers 8
H Front Driver side Axle binding Stock 2006 -2010 Explorers 0
J Clink noise from front end Stock 2006 -2010 Explorers 2
S 2010 V6 4x4 front Axle removal. Any How To's? Stock 2006 -2010 Explorers 2
P Front Differential Rebuild - Temporary 2wd Stock 2006 -2010 Explorers 3
G Arrrrgggg Front hub stuck/frozen on 2010 4X4 v8 Stock 2006 -2010 Explorers 25
D Front lower ball joint part no. question Stock 2006 -2010 Explorers 0
D Front hub/axle question Stock 2006 -2010 Explorers 7
J Squeaking front end Stock 2006 -2010 Explorers 1
M Front U-joint Stock 2006 -2010 Explorers 4
H under body rust, and front wheel camber Stock 2006 -2010 Explorers 0
A 2006-2010 Explorer AC Vacuum lines (Air not blowing from the front vents) Stock 2006 -2010 Explorers 0
J 5r55s - If front pump goes out, is trans garbage now?? Stock 2006 -2010 Explorers 3
P 08 Ltd 4.6L Front drive line buzzing noise/vibration Stock 2006 -2010 Explorers 6
0 Some front end advice please Stock 2006 -2010 Explorers 14
W Front grill emblem size Stock 2006 -2010 Explorers 1
W front strut spacer install Stock 2006 -2010 Explorers 4
digifoss front grille differences Stock 2006 -2010 Explorers 14
T Front wheel locking up Stock 2006 -2010 Explorers 11
S Front Wheel Hub Bearing Stock 2006 -2010 Explorers 14
E 2010 AWD front camber issue Stock 2006 -2010 Explorers 0
S Hard knocking sound on low gear from front diff ????? Stock 2006 -2010 Explorers 0
F front wheel bearings Stock 2006 -2010 Explorers 26
Similar threads
