front bumper/grille guard
ironicRDS
california
1996 ford explorer
so i was wondering if anybody out there knows what kind of other trucks/suvs have about the same shape and size as a 96 xlt because im a sixteen year old and don't have a lot of money due to the lack of a job but i want a good looking bumper maybe off Craigslist that will fit with out too much trouble
what should i be looking for/ measuring
thanks for reading
DjDom
Moderator Emeritus
Toronto, Ontario
97 XL(imited)
By bumper, do you mean a front brush guard and such?
Only one from/for an Explorer will work.
Any other ones would require a lot of work to fit.
dcdyd
Eden Prairie, MN
98 Explorer
T Front bumper removal Stock 1995 - 2001 Explorers 1
B 2000 Eddie Bauer front bumper cover assembly Stock 1995 - 2001 Explorers 5
G Front Bumper Alignment Stock 1995 - 2001 Explorers 2
T Explorer sport front bumper removal? Stock 1995 - 2001 Explorers 1
M 1998 Mountaineer Front Bumper Paint Stock 1995 - 2001 Explorers 9
A 2000 XLT front bumper diagram needed Stock 1995 - 2001 Explorers 0
N Front bumper change out question Stock 1995 - 2001 Explorers 0
S 2nd Gen Explorer front bumper question??? Stock 1995 - 2001 Explorers 8
C 2nd Gen (2000) Front Bumper Bolt Removal - HELP Stock 1995 - 2001 Explorers 2
A Front bumper trim/cover removal (2000) Stock 1995 - 2001 Explorers 2
L front bumper Stock 1995 - 2001 Explorers 1
T 98xlt front bumper Stock 1995 - 2001 Explorers 0
1 Front Bumper/Fender pushed to tire Stock 1995 - 2001 Explorers 2
RiccoFX Front Bumper Swap! Stock 1995 - 2001 Explorers 33
S Front Bumper Bolts will not budge. Stock 1995 - 2001 Explorers 6
S Front bumper Stock 1995 - 2001 Explorers 6
I Removing Front Bumper Cover Stock 1995 - 2001 Explorers 1
F Front bumper bent, help please Stock 1995 - 2001 Explorers 1
K 99* Front Bumper License Plate Stock 1995 - 2001 Explorers 4
9 Front bumper? Stock 1995 - 2001 Explorers 13
N Swap Front Bumper 97 ranger for one off 98 Stock 1995 - 2001 Explorers 1
P need advice for a front bumper Stock 1995 - 2001 Explorers 0
Kris Guilbeaux Need 97 limited front bumper help Stock 1995 - 2001 Explorers 7
G front bumper disasembly Stock 1995 - 2001 Explorers 3
M 95-97 steel front bumper, different in size from 99-01? Stock 1995 - 2001 Explorers 7
D How to replace front bumper Stock 1995 - 2001 Explorers 5
R 99 Front Bumper Swap Stock 1995 - 2001 Explorers 6
T Front Bumper Schematic Stock 1995 - 2001 Explorers 5
F Anybody know how to replace the front bumper on a '99 ford explorer? Stock 1995 - 2001 Explorers 7
B Need a front bumper Stock 1995 - 2001 Explorers 12
F 01-03 explorer sport front bumper Stock 1995 - 2001 Explorers 1
Sbyrne97 Front Bumper removal Stock 1995 - 2001 Explorers 4
9 Light on top of front bumper.. HELP Stock 1995 - 2001 Explorers 4
0 Buying 2000 Limited with no front bumper Stock 1995 - 2001 Explorers 2
R bolting 99-01 front bumper on 97 Stock 1995 - 2001 Explorers 2
S Removing front bumper Stock 1995 - 2001 Explorers 9
T Front bumper on a 95 explorer Stock 1995 - 2001 Explorers 5
Z Front Bumper Cover Stock 1995 - 2001 Explorers 0
H Front Bumper Stock 1995 - 2001 Explorers 1
F To remove the busted Front bumper Stock 1995 - 2001 Explorers 3
V front bumper lip removal Stock 1995 - 2001 Explorers 2
E Term For Plastic Part Above Front Bumper HELP!! Stock 1995 - 2001 Explorers 2
Hacra Front differential replacement (easiest way?) Stock 1995 - 2001 Explorers 0
G Front drive shaft thread size and pitch Stock 1995 - 2001 Explorers 2
P Front wheels not being driven Stock 1995 - 2001 Explorers 9
TsherryUSA Front Shock QC question Stock 1995 - 2001 Explorers 3
B Front door lock actuator, "helper spring" replacement Stock 1995 - 2001 Explorers 1
S 2000 mountaineer 5.0 v8 awd vibration coming from front end Stock 1995 - 2001 Explorers 2
T 1996 Ford Explorer front diff Stock 1995 - 2001 Explorers 4
B Front drive shaft 2000>1997 Stock 1995 - 2001 Explorers 4
Similar threads
