Front Camber Adjustment - $200? | Ford Explorer - Ford Ranger Forums - Serious Explorations
KBoomBoxx
Stanardsville, VA
1994 Ford Explorer XLT
Just brought my 94 x to the garage and they want $200 for mounting and balancing 4 tires, as well as fixing the front camber issue... top of tire is dipped in causing major wear on the inner tire tread... I know that my technical terms are not correct, but I can't remember the cast vs. camber thing... seems that $200 is good, but wanted your opinion... $70 is the alignment and $15 per tire for mounting and balancing... the rest is the fixing of this camber issue...
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
$100 too much IMO, unless it requires new camber correction shims.
Rotaote and balance = $8 per wheel so $40
Alignment = $70
$110 -$130 max I would pay here in Colorado
KBoomBoxx
Stanardsville, VA
It ended up costing me $242 total... 4 tires mounted and balanced, all wheel alignment and $70 shim kit installed in the front...
best $240 I ever spent... car rides 10 X better... front end was so out of alignment that it now drives normal and I can notice...
