LJP326
- August 27, 2018
- New York
- 2018 Explorer Limited
Just sharing my experience with my leased 2018 Explorer Limited @12K+ miles. Detected oil leak, garage guy lifted the car, it looked like from the OP gasket especially at the corners. After changing the oil (it was scheduled for 12K) and new "plug", leak persisted. Back on the lift from the garage (not ford yet) and my guy said its coming from "higher up." So now to the dealer...a plus with the lease. They first said because the garage guy "changed the plug" (to see if that was the cause), it was his fault. So they changed the plug for a small fee, (I think my car had 3-4 oil changes!). Finally it still leaking and since Ford was the "new plug" installer it went back. After further inspection, the leak is coming from the FRONT COVER which they had to remove, clean, replace, seal; whatever and 4 days later w/o loaner. So if you have a persistent oil leak and the OP isn't the problem, it may be coming from higher up. The diagnostic code shows L 3448 W. Just sharing my experience. I do like the car and the lease is up in September and I'm doing homework but not seeing what I like. I might go to the XLT with options vs. the high price for the Ltd. Homework homework homework.
