Front differential leak
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
I have a 2004 ford explorer with a front differential leak its not coming from the differential gasket and I confirmed this by dropping front diff cover scraping old gasket and made a new one with RTV and same as before the leak is coming from the driveshaft seal and its a very slow leak. Firestone diagnosed it almost 2 years ago but it barely drips. Can anyone tell me how difficult this job would be. Might be something for my mechanic if I'll be disconnecting drivelime components. Has anyone had this done?
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@XLTyler83
Of course, we've been replacing pinion shaft seals forever. Requires knowledge of pinion bearing preload, no guesswork, unless you are willing to chance making hamburger of your front gears. Keep in mind, there are 4 places leakage can occur, and that driveshaft spinning along with wind draft, can make it look like oil leakage is HERE, when it's actually THERE. imp
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
Thanks my 04 and I appreciate it. What four places can leakage occur and just so I can get an estimate in my head of labor costs how many hours do you think this job should take?
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
5 possible leak spots,,
axle intersection left cv,(where the cv pushes inside)
axle intersection right cv,
pinion seal,
cover gasket,,
fill/level plug hole,,
XLTyler83
Myrtle Beach SC
2004 XLT 4x4 Loaded
thank you thats awesome. how would one go about pinpointing the leak or leaks being as theres 5 possible spots?
imp
Location
pinion seal,
cover gasket,,
@corkey
Yeah, you're right. I meant only 4 places because I don't think I've ever seen a failed plug hole! imp
