anisaparks
- January 9, 2015
- 2010 ford explorer
I am swapping out the front differential (Dana 35/194 front with cv joints) on my 2000 explorer due to bad pinion bearing. I picked up a low mileage replacement from a wrecked 2004 that was listed by the junkyard as compatible. I do not have the skills or tools to rebuild the old one. Both are 4.10 gear ratio.
I noticed the new unit does not use bearings where the CV joints fit into the differential but has machined bushings instead for the right side half-shaft in the tube. Should I use the old CV axles or should I replace with ones for a 2004?
The bill of material number for the old axle is 610774-4 and the replacement is 2002750-2. Looking on the Dana website it confirms the 2004 differential does not use bearings where the CV axles attach.
