Mtredneck
- July 12, 2020
- Dillon
- 2015 Explorer XLT, 3.5L V
2015 Ford Explorer XLT 3.5L V6, Everything stock.
I'm the third owner and bought this from an owner who lived on county gravel roads so I know it got plenty of washboard and rough roads in it's first 100k.
I get a pretty decent clunk that sounds like maybe the front right side when I hit any minor potholes. Distinct clunk with rebound clunk a couple times. I read forums and confirmed my suspicion of likely sway bar noise, maybe tie rod, or sway bar links.
Since I want a stable front end for wife and kids I just swapped out inner and outer tie rods, sway bar links, sway bar bushings...still getting the clunk. All parts replaced showed wear enough that it was a good call to replace for regular service. Also had a twang when steering hard back and forth so I replaced both front strut assemblies. That solved the twang sounds, but still have the clunking when hitting any pot hole.
Zero play in the wheel when I check wheel bearings and ball joints (done this a few times because I want to blame ball joints). Read some more and decided engine mount is suspect, so I changed the front right engine mount tonight...still getting the clunk.
I'm running out of ideas on the cause here. I removed that transmission cooling intake doohickey underneath just to see if that possible was the cause, but the clunk is deep enough it sounds very much like a suspension issue. The fact if I rock the car even fairly slowly (10mph) through a pot hole I get this 3 or 4 clunks back, I keep thinking suspension. I took a hard look at the lower control arms with their rubber bushings and can't see anything suspect, and cant get any play on them when I mess with em.
At this point I feel the only things left are the second motor (transmission mount), control arm bushings, or ball joints that are currently passing my checks.
What am I missing on this damn clunking?
