fastkurve
- October 20, 2005
- Longueuil, Quebec, Canada
- 2004 XLT SOHC
Had 4 wheels bearings replaced 2 years ago, done about 25k since then.
Jacked the truck on stands last saterday, and had my younger son keep the engine rev'ing at 2000 rpm, check at all rolling elements with a stethoscope, everything was fine, beside the front differential being very noisy when probing it.
So, had the truck checked at the shop today, told me that the front differential bearings are shut. (he checked it with a stethoscope too, but I did not told him I done it on my own before, I was curious to find out if he was ending up with the same diagnostic than me)
Question for you guys:
What should I expect in term of price to do the job ?
In my mind, if it is only a matter of replacing all bearings & seals, cleanning and removal/strip/rebuild/install , this should be very similar to a rear end job.
The shop asked me 750$ for the differential and 300$ labor....seems too much to me , what is/are your experience about this ?
thanks for sharing,
Robert
thanks for sharing,
Robert
