DryDog
- February 14, 2004
- Woodbury, MN
- '91 XL
Not sure where to post this. Not quite a 911 But it is sure a scary noise.
1st heard it backing out of a parking spot, wheels cranked right. The right front sounded like the knobby part of tire rubbing against fender. But it wasn't. Then I couldn't reproduce it. My tie-rod end seals were split. I had to change them anyway, I figured maybe this was it. When I replaced them I screwed up the alignment. Took it to Car-X for alignment. They showed me my wheel bearings were loose (from a recent brake job, my 1st) I followed a thread here an fixed them.
A few days later making a quick sharp left, the left front made a metalic crunch and I could feel it in my feet. I took it to Tires Plus for the alignment and to diagnose the noise. They said the noise is from a cupped tire. They left it on the front and said it would wear in now that the alignment is correct.
I swapped both front tires to the rear. I still get the noise! Rubbing noise in right front, metalic crunch/grinding noise in left. I read that cupping can come from bad shocks so I replaced them Saturday. It changed the ride but not the noise. I'm making wide sweeping arcs, driving like an old lady. Please help
