sabresfan
- September 25, 2008
- Buffalo, NY
- 99 Ranger 4X4
I have a 99 Ranger 4X4 with 127K miles. I have a loud humming coming from the front end while driving. I can also feel the slight vibration on my feet. I realize with the high mileage the easy answer is to replace the hub assembly but I am hoping to identify which side. The sound goes away completely when turning to the right. I changed the passenger side and the sounds did NOT go away. Before I swap out the drivers side, can anyone give me some other ideas as to what it could be? It's at it's loudest around 30-35 mph, goes away when I turn right and has gotten progessively worse over the last year or so. The truck has new tires and the passenger side hub assembly has been replaced. Are there other bearings behind the half shafts inside the assembly that may need to be replaced? I am just trying to find out how many sets of bearings there are in the front end. There does not appear to be any "play" when testing the wheel bearings by doing the old wheel bearing test.
Thanks in advance!
Thanks in advance!
