front end noise? | Ford Explorer - Ford Ranger Forums - Serious Explorations
front end noise?
catdaddy614
columbus, ohio
97 XLT
When im just sitting there and I cut the wheel, I hear a creeking noise coming from the front like something with the suspension. what do you guys think it is and how would i diagnose a problem like this?
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
More than likely ball joints or tie rod ends. Possibly sway bar bushings or sway bar links.
catdaddy614
columbus, ohio
97 XLT
would that also cause a slight hum noise to the front end?
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
2wd or 4wd?
The hum could be the alignment is off from the bad ball joint or tie rod end. Those parts going bad will cause the tire to "drag" in a sense.
Replace the ball joints and tie rod ends then take it for an alignment ASAP afterwords.
