JustAnotherMember7
- May 12, 2020
- Twin Falls
- 2001 Explorer XLS
It's been a while, but it is time to get my ride reliably running again.
Ball joints MUST be changed, as well as wheel bearings.
Rotors and brake pads are midline acceptable but I'd like to change them out and bleed the brakes.
Outer tie rod boots are not torn, but the car has 145,000 miles and they are original.
Here is my parts list, is this way too expensive (825$), or does it line up with what I am wanting to do?
What can I do to decrease the cost but get good quality parts?
- Front Left Upper Control Arm 81.99$
- Front Right Upper Control Arm (Ball Joint) 57.99$ (new bushings will be pressed into the 2 piece design) 12.99$ x2$
- Front Left and Right Lower Ball Joints 48.99$ x2
- Front Left Outer Wheel Bearing 5.99$
- Front Left Inner Wheel Bearing 6.79$
- Grease Wheel Seal 7.59$
- Front Right Outer Wheel Bearing 5.99$
- Front Right Inner Wheel Bearing 6.79$
- Rear Wheel Bearings with grease seal (left and right sides) 14.99$ x2
- Rear Diff Shock Absorber Dampener 34.53$
- Pennzoil Synthetic 5w 30 oil 27.99$
- Motorcraft O.E. Oil Filter 8.99$
- Front Rotors 78.99$ x2
- Front Brake Pads 49.49$
- Rear Rotors - 47.99$ x2
- Rear Brake Pads 48.99$
- Left Outer Tie Rod 39.99$
- Right Outer Tie Rod 39.99$
- Lower Control Arm Bushings 17.29$ (Each*, x 2)
