dr fildo
- May 1, 2012
- 1999 Mercury Mounaineer
I have a wobble, shake, shimmy, whatever it's called. Happens over 55 mph. Is not constant; sometimes it's smooth as glass at 60 mph, sometimes it shakes fairly violently. Doesn't stop shaking going over 80 mph, but it is less shaky. 25k on new steering rack (inner and outer the rods), and it has newer rotors and pads. Very old shock absorbers. I don't think it's the wheels/tires, as it was happening before and after tire rotation. A mechanic recently told me my ball joints look good, although they have almost 230k on them. I do believe the driver's bearing/hub assembly needs replacing. At slow speeds when braking, it almost feels like a warped rotor, but I've changed them out and it still does it. No uneven wear on the rotors or pads. No pulsing of the brake pedal.
Any ideas on what it could be? It's getting worse.
