Front Engine Cover Oil Leak on Explorer Sport
bigtexan99
2016 Explorer Sport
When I was installing the new Raptor style grill on my Sport, I noticed a little leak. See attached picture. There is no oil puddle on my garage floor. Took the Sport in for the C02 concerns fix and showed the Service advisor the pic and he said he would check it out.
Today he called and said the oil is leaking from the front engine cover, and the oil filter adapter. The are going to open up the engine and replace the engine cover gasket, and several other gaskets.
Will update when I get it back next week. By the way, I only have 9600 miles on my 2016.
shucker1
Metairie, Louisiana
98 XLT 5.0
Warranty...
bigtexan99
2016 Explorer Sport
AFAIK its all covered under warranty. Don't see why it wouldn't be. Service adviser made no mention of any costs when he called to give me the update.
FordShelby
Blue Ridge mtns VA
2016 Sport
Good to hear the warranty is taking care of you.
bigtexan99
2016 Explorer Sport
I stopped by the dealership unannounced to see how the job was going. We walked back and took a look and I met the mechanic. My first impression of the mechanic was "thank god". He was older, clearly experienced, and gave me a quick overview of what they were doing. Interesting that the front engine cover does not have a gasket, its just a thick bead of sealant. Here are a couple of pics of the open engine, and the front engine cover itself.
bigtexan99
2016 Explorer Sport
Got the Sport back and so far so good. They resealed the engine cover, replaced the valve cover gaskets, replaced the oil filter adapter and gasket, replaced the high pressure fuel line from the pump to the rail, and new V drive belt. Changed the coolant, oil and oil filter All under warranty, no charge.
Mlarv5
Crossville TN
2017 Platinum Ruby Red
Wow I love the look of a clean engine. It is sort of common for the front cover to not have a gasket anymore. The sealant is applied by a robot in the factory, the robot that did your must have been close to break time(-; Glad they go it fixed up for ya.
shucker1
Metairie, Louisiana
98 XLT 5.0
Or it was Friday afternoon and he wanted t get home to his robot wife "Rosie"....
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
Rosie was a Riveter robot. The sealant application was her cousin.....Wait for it.....!!!....Flow...
All kidding aside I an believe they used about 14 cents worth of sealant instead of 17 cents worth of Gasket material. Probably some bean counter weenie who has probably never even heard of oil changes much less done one themselves. They will save the .03 cents and bank on the sealant lasting forever...or at least until the warranty expires.
Unfortunately way of the world, not just Ford and not just automobiles...…. I bet if you really dug down deep you would find that the Gasket maybe cheaper in the long run with overall longer reliability and reduced warranty claims, bad survey and reliability reviews.
Stephen Cannon
DFW METROPLEX
2018 Explorer Sport
Kudos to the service advisor and mechanic for wanting to talk to you and show you the problem. Most people would just take the S/A word and move on. For anything this serious especially with low miles then I would insist on seeing the damage and talking with the tech. Even better allowing photos to document the repair.
Ironworker40
new jersey
2015 Explorer XLT
That's the kind of dealer I like. Most of them will give you the "you can't go back there because our insurance won't allow it".
I don't ask. I just walk in they the open bay doors. Anyway what is the name and location of that dealer? Someone else on here may be looking for a good dealer in that area.
S 2018 Explorer - Front passenger side creaking sounds when accelerating from stop Stock 2011 - 2019 Ford Explorer Discussion 4
M Front End Clunking Over Bumps Stock 2011 - 2019 Ford Explorer Discussion 4
Bobs2018Explorer Missing front bumper plug, for a front tow recoveryhook? Stock 2011 - 2019 Ford Explorer Discussion 2
B Front end clunk shifting out of park Stock 2011 - 2019 Ford Explorer Discussion 3
D Rattle from under front of vehicle when AC on Stock 2011 - 2019 Ford Explorer Discussion 5
W Disable front parking aids 2017 explorer Stock 2011 - 2019 Ford Explorer Discussion 2
M Looking for help with front seat removal Stock 2011 - 2019 Ford Explorer Discussion 3
N Grinding/rattle from front of car when AC is on Stock 2011 - 2019 Ford Explorer Discussion 4
T Problem installing the front license plate frame Stock 2011 - 2019 Ford Explorer Discussion 4
M Uneven front pad wear? Stock 2011 - 2019 Ford Explorer Discussion 6
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 17
B Popping/grinding noise coming from under the front end when steering left or right Stock 2011 - 2019 Ford Explorer Discussion 4
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
G need help with front assist parking camera Stock 2011 - 2019 Ford Explorer Discussion 1
B 2014 Ex. Sport - $1,600 for front brakes and LCA bushings? Stock 2011 - 2019 Ford Explorer Discussion 12
E labor units about front apron panels replacement Stock 2011 - 2019 Ford Explorer Discussion 11
B Heated and Cooled Front Seats Stock 2011 - 2019 Ford Explorer Discussion 2
J Correct separator tool for ball joint @ lower control arm(front) Stock 2011 - 2019 Ford Explorer Discussion 5
B Front Washers Stopped Working Stock 2011 - 2019 Ford Explorer Discussion 12
B 2014 Limited Driver Side Front Window Inoperative Stock 2011 - 2019 Ford Explorer Discussion 0
A Front seat movement when using keypad to unlock Stock 2011 - 2019 Ford Explorer Discussion 4
L Why the tiny "cup holder" in front center console? Stock 2011 - 2019 Ford Explorer Discussion 13
K 2011 Banging noise in front, need help Stock 2011 - 2019 Ford Explorer Discussion 14
D 2015 Sport - Non HD Front Pads....? Stock 2011 - 2019 Ford Explorer Discussion 3
R Recall 19S17 and front alignment q's Stock 2011 - 2019 Ford Explorer Discussion 25
ddaniel13 2019 Limited cooled front seats Stock 2011 - 2019 Ford Explorer Discussion 9
K Static in front speakers Stock 2011 - 2019 Ford Explorer Discussion 7
J 2013 limited front exhaust pipe break (by flex joint), what to do... Stock 2011 - 2019 Ford Explorer Discussion 10
B Front end damage ? Stock 2011 - 2019 Ford Explorer Discussion 12
G Explorer 2013 front driver side louver handle cap Stock 2011 - 2019 Ford Explorer Discussion 8
J Rattle coming from under front of vehicle Stock 2011 - 2019 Ford Explorer Discussion 20
W 2018 Ford Explorer Damaged Front Camera Stock 2011 - 2019 Ford Explorer Discussion 6
Bobs2018Explorer 2018 Explorer XLT - Front Tow Recovery Hook? Stock 2011 - 2019 Ford Explorer Discussion 20
N Adding front parking sensors Stock 2011 - 2019 Ford Explorer Discussion 4
J 2013 explorer XLT front caliper suspension bushings Stock 2011 - 2019 Ford Explorer Discussion 3
K Front Passenger Axle Seal Leak Stock 2011 - 2019 Ford Explorer Discussion 2
B Front & Rear cameras shortcomings Stock 2011 - 2019 Ford Explorer Discussion 3
N 2016 front door 6x9 mounting depth Stock 2011 - 2019 Ford Explorer Discussion 1
S Should I remove the "Explorer" front hood emblem?? Stock 2011 - 2019 Ford Explorer Discussion 5
B Front end clunk - even in park Stock 2011 - 2019 Ford Explorer Discussion 4
I 2017 explorer front right axle leak Stock 2011 - 2019 Ford Explorer Discussion 14
R 2014 front windshield defogger is forced air only? Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport - Burning Smell in front Stock 2011 - 2019 Ford Explorer Discussion 6
M 2016 Explorer Front End Wiring/Plug Help Stock 2011 - 2019 Ford Explorer Discussion 3
R Front strut replacement 2013 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 4
P External Front Lamps always on? Stock 2011 - 2019 Ford Explorer Discussion 5
realscot2 Front End thunk Stock 2011 - 2019 Ford Explorer Discussion 6
D Intermittent Front-End Hum - 2014 XLT Stock 2011 - 2019 Ford Explorer Discussion 2
E Front Rear Tire Wear Question Stock 2011 - 2019 Ford Explorer Discussion 2
D Side to side bar under the back of front seat? Stock 2011 - 2019 Ford Explorer Discussion 5
Similar threads
