front hub bearing | Ford Explorer Forums - Serious Explorations
front hub bearing
freankg521
tewksbury MA
2004 ford explorer
Hi all I am in the middle of changing a 2004 left front bearing and I cannot get the axle all the way through the bearing. changed the right it went smooth is their an install tool/sleeve to install?? what size it the thread in the axle mabe I can spin one out on the lathe
thanks in advance
Not sure what you mean.
Do you mean you can't get the bearing hub to slide off the splines? Is it loose from the knuckle?
Hi No I have it apart when assembling... the spline will not go in enough to grab the treads to pull it in.. im looking for a install tool
Take the hub off, grease the splines (if you haven't done so already), insert the axel into the hub (you'll have more play with the axel through the knuckle) and start the hub nut, then install the hub to the knuckle. Then torque it all down.
