ExploGoldRob
- June 3, 2007
- 00 Sport
Hi, all. 00 Sport 4Wdrive. Started having noise while turning. Visually all appears OK from the tires to the suspension to the axles, etc. I posted before, but now the condition is serious. To the point it's unable to drive even straight. It feels like something is locking up or rubbing, as if the brakes are applied. And makes a howling sound from inside. I had to creep home at 15 mph. Can I remove the front drive shaft ? To try to isolate what this problem is ? Is it inside the front differential ? Both c-v axles and hub were replaced 2 years ago. Has anyone had this symptom ? Thanks.
