EB4X
- December 28, 2016
- Orange county, Ca
- 95 Explorer 4X 4.0 ohv
Hey gang,
So front axle is not engaging when putting in 4x4 (immediate/low..surely auto as well)..
The transfer case DOES engage but the mechanics/ or whatever is not connecting the front axle.
I crawled under and pulled the vacuum line at the vacuum actuator / engage mechanism to see if that was the problem.... had buddy put into 4 low with vacuum line off to feel for vacuum upon switching but having that pulled (even there) disables the transfer case from being engaged, stops entire process, once plugged back in the transfer case will then work / engage.
I then jacked all four tires off the ground and engaged 4x4 to see if front would turn at all without all the weight of vehicle (to see if maybe a slipping issue) but no front wheels turning at all in 4x4 / in drive / giving it gas.
The 4x4 lights flash twice when turning the switch / engaging transfer case.....once engaged the 4x4 light will NOT come on anymore, letting you know it's engaged but can hear the transfer case clunk during engage / disengage.
Is there any usual culprit that is first to go in this scenario ?
1995 model.
410...where are you! ?? ! ! !
1995 model.
