SHUMAX
- December 30, 2002
- Ohio
- 2019 Explorer Sport
Some of you that have followed me through my quest with my 2011, and now my 2014 Sport, know I'm not a fan of clunking in the front end or a wobbling steering wheel. See thread from the 2011
http://www.explorerforum.com/forums/showthread.php?t=428804
The 2014 now has about 48k on it. At 38k, the front struts were replaced with the strut bearings as the struts were leaking. From there, around 45k, I had the front sway bar links replaced. Then, the front sway bar bushings. The noises in the front went away about 95%.
What I started to notice was the random shaking of the steering wheels around 45-55mph. Sometimes it would happen, others it would not. No real reason for it. I had the tires balanced on a road force machine that was calibrated a week before I went in - road force figures in the front were under 10lbs. Over the last 3,000 miles, it had started to do what the 2011 was doing -- slight wobble of the steering wheel at 45-55mph. What fixed that on the 2011 was new control arms and rear control arm (hydro) bushings.
Thinking that's what I was facing now on the 2014 Sport, I decided I would try something from my Honda days. I bought a tube of 3M Window Weld. I used that, in the past, to fill motor mounts. Before you bash me for it, stop. I realize it's likely a temporary fix; however, what it would tell me was whether it was the rear hydro bushing or the front.
$22 later, I had a tube of it. http://www.summitracing.com/parts/tes-08609?seid=srese1&gclid=CNr56Y-ZzcwCFcNahgodPAEMDg
I jacked the car up and filled both sides of the bushing in so there were no gaps. http://www.ebay.com/itm/Suspension-...ash=item51dcf1cd9f:g:jd4AAOSwPc9Wvo1K&vxp=mtr
See the gaps in the bushing? Fill those - front and rear. The stuff is sticky as all get out and makes a mess - wear gloves. 30min. later, both bushings were done. I let it dry 12 hours and took it for a drive. Immediately, I noticed the front end was tighter. The random thumping is gone and guess what - no shimmy from the steering wheel.
I am convinced this bushing is weak in our suspension. With time, it can't keep the control arm stable and it results in the clunking and random shimmy. Now, when/if the window weld comes out, I can replace the bushing and move on. They are $100/each from Ford; however, I've seen them online for $60. Bad thing is that you need to remove the entire control arm. Depending on the miles accumulated, I may just replace the entire arm and rear bushing.
FYI for those that run into the same issue. Very happy with how it feels and sounds!
Shumax
Shumax
