Afboy143
- September 23, 2003
- Tampa,FL
- 1999 Ford Explorer Sport
Hey guys,
A problem just started with my truck. When I go over bumps, a metal on metal running noise occurs on the front right tire. Kind of like a hollow rubbing noise like the rotor is rubbing on the heat shield. This noise occurs at any speed. It occurs going over bumps, even slight ones, but bigger the louder. It also happens if I turn left at higher speeds putting pressure on the front right tire. This is when the noise gets really bad. Also I noticed when I go over speed bumps it makes the initial noise followed by a constant noise that eventually fades away after driving. On even ground everything is silent.
I checked the brake dust shield and it looks fine. I checked the bolt that holds the rotor onto the spindle, still is tight. I can't figure out anything else that it might be?
