Front Spindle swap Question?
vq5speed
1991 XLT Manual Locks
Stockton,Ca
I trashed my front bearings and spindle on my 91. Are the Spindles that come on the manual locking hubs the same spindle on the Auto locking hubs? I need to get a Spindle from the yard and if I can't find an Ex with Manual hub are the Spindles on the Auto hubs the same..
I'm thinking there the same. Because was looking at kits to change from Auto hubs to manual hubs they don't show you need to change the spindle..
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Yes, same. If you're going to pull some off an Ex with auto hubs, make sure you know about the little key in the inner hub and how to remove it.
vq5speed
Stockton,Ca
Yes I found that out. Had a hell of a time figuring how to remove that key. Found a piece of thin metal mesh off a tweeter. Was able to rip the screen into a point and slip it between the nut above the key and pulled it out. Then there was some other weird thing I guess some sensor I basically pounded it off hahaha. Then there was this bolt on the back and didn't bring any small wrenches but found someone who let me used there crescent wrench then finally!!!!!!! it came off! hahaha
92exp4x4
Covington, Kentucky
92 XL 2-door and others
I'm usually able to get a magnet to work in getting the keeper out, you right though they are a pain. The sensor was for the ABS. It's the wheel speed sensor. Explorers got 4 wheel ABS in 93.
