Are the outer parts of the TTB still level with the ground after the cut and turn? If the part the spring sits on isn't level, of course it will bow out and curve in going back to the upper spring seat.
If the springs are too long, they can bend like that too, especially with weird geometry created when a cut-and-turn is done without taking into account the spring length and position of the bottom mount. This can happen if a jig isn't used to keep everything lined up correctly, and the beams are just cut and turned without adding the extra material needed to keep the track width and spring positions exactly the same.
The springs also need to sit a certain way in the upper seat, if they aren't turned to their correct position, they can be in a weird bendy position.
If it's just a slight bend, it might be normal until the suspension settles, especially if they are new springs. If it's a severe bend, you should check the spring position, and if that looks ok, check out some other cut and turn TTB's and see if yours was done correctly.
