Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
I have a metal to metal clicking noise in my front suspension and have had it for some time. I thought it might be the Torsion bar Insulators but after lots of asking around, many people told me that this part rarely if ever fails.
I snooped a little deeper into this problem by crawling under my X on my back. I grabbed the Torsion bar at the back mount on the drivers side and pulled hard, no movement at all. I did hear a small click which seemed to be coming from the front suspension assembly. Next I rocked the truck by bench pressing the side frame up and down till it rocked the truck. I heard the noise several times coming from the drivers side, front suspension area.
The final test was to drive the vehicle in small circles. When I drove the truck counter clockwise with the wheel cut all the way to the left. I heard the clicking noise and the truck seemed to stumble on its footing several times. I also notice this when I pull out of a parking space in reverse. When I drove the truck clockwise with the wheel cut all the way to the right, I noticed nothing wrong just tight suspension. Leading me to believe the problem is in the drivers side area.
I recently replaced the shocks, Sway bar bushings and links. The tie rods are tight. Ford Dealer supposedly replaced the Ball joints upper/lower for a cost of $1250. Strange though when I took it to another Ford dealer a few weeks after. They said one of the ball joints was deffective- I took it back to the original dealer and an argument insued. They told me the other Ford dealership had no right to make such an accusation and the ball joint was fine. When I threatend to sue them and contact Ford management they took in the vehicle and supposedly fixed the problem. I have no Idea what they did if in fact they did anything. I know I should have but I never got a second opinion.
What are the symptoms of a bad ball joint??
I appologize for the long thread.
