Front Wheel Bearings - Are the Inner and Outer Identical? | Ford Explorer Forums - Serious Explorations
BoostedE21
Hey folks,
I lifted the front end of my 91 4x4 off the ground today and found horizontal and vertical play in the wheels....So I'm following this guide to replace my front wheel bearings, and doing the brakes at the same time:
I'm aware that the bearings can generally be reused, but my replacement rotors already have races installed, so I'm going to replace the bearings too. My question is - are the inner and outer bearings the same size? Autozone seems to only show the SET 37 bearings and the 4250 inner seal...
Thanks in advance!
Yes they are the same. I recommend getting a quaity bearing like Timken over those Duralast ones and also replacing the cheap races that came with the rotor with ones from the same bearing manufacturer in most cases. The pre-pressed in races have been known to cause problems or fail in the past so I always swap them out.
