Front Wheel Bearings | Page 2 | Ford Explorer - Ford Ranger Forums - Serious Explorations
SuperKirby
Central MN
1993 Explorer XLT
What do I need to torch? I should have about everything else except for the spindle nut tool. We have some pretty massive sockets floating around for the tractor, as well a 2 torque wrenches. I believe one is inch pounds and one foot pounds.
I'll order the bearings, seals, and a u joint here in the next couple weeks and as soon as it's nice enough on a day off I'll see what kind of damage I can do.
2stroke
Location
55302
Annandale, MN
1993 Ford Explorer Sport
You most likely need a torch to get the spindle off. I always do, even though I put it back together with anti sieze.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
I use a small sledge and a short piece of 2x4 to loosen the spindle. The wood protects th threads on the spindle. Bang, bang, bang some more and it's off.
I've never replaced the bearings in the spindle in The twenty years I've owned my truck. I have replaced the spindles with other used spindles, though.
I get the hub orings at Napa. I believe the part # is 727-2153.
If you want to clean the hubs, fill with ATF and let soak while you do the bearings. Then dump out and let drip dry a little, and reinstall. No need to add grease.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
For what it's worth, I went all the way in to U-Joints on mine and didn't have to use a torch but that's because I didn't have one at the time. Just an impact gun and a wrench.
I do live in the northwest and don't have to battle vehicle rot from salt. Watching videos from South Main Auto on YouTube, he's up in the northeast and some 10 year old cars I see roll into his shop have more rust than my Explorer. Amazing that the city/state allows that.
I highly recommend replacing the spindle bearings. They're an overlooked maintenance item that can cause a lot of 4x4 noise. NAPA BRG BK1 will fix you up.
Regarding the o-rings, they're a special kind that have flat sides. You can probably get away with a regular o-ring or RTV but I'll help you out. Call up MileMarker and get part number 428-03. They were $10-15 for the set, shipped. That's the original o-rings included with the MileMarker 428 manual locking hubs for the Explorer. I imagine the Warn ones have the o-ring in a very close spot. I can verify if someone gives me an ID or OD of the Warn ones.
Another thing I forgot to say is that with the manual hubs, having the o-rings installed doesn't mean you'll be safe from water. Based on recommendation from this site, I wanted to clean my manual hubs up so I soaked them in ATF. That is, until the ATF trickled out the bottom. There's no sealing on the selection knob end of the hub so if you get that dipped into water, it's going to get into your wheel bearings, no doubt about it. Regular road grime and moisture/rain shouldn't though.
